eunacom Posted November 18, 2011 Report Posted November 18, 2011 I have a older Delta 22-540, 12" portable planer. I removed and sharpened the blades, using a Mini Planer Pal magnetic jig set. When I re-installed the blades the feed rollers don't seem to make firm contact and need a gentle 'push' to feed the materiel. Also, there is a very slight 'washboard' effect to the planed surface. There were no problems (other than nicked blades) before I sharpened and re-installed them. Any ideas on what is causing the slipping feed and the wavy, 'washboard' effect or how I might correct them? Any help would be appreciated. Stan Quote
jimmykx250 Posted November 18, 2011 Report Posted November 18, 2011 Washboard effect is a result of eneven blades. I know this because i got the same result when I did my jointer knives. As far as the rollers go I had a problem with my 22-560 and had to replace the infeed roller after quite a few years of service because it just wasent grabbing the material any more. They say you can clean the rollers and I tried with no favoriable results. With mine one i pulled the infeed roller it was pretty obvious it needed to be changed. Wish you luck. Quote
eunacom Posted November 18, 2011 Author Report Posted November 18, 2011 Thanks for the tip. I think I'll replace the knives with new ones and see if that solves the problem. If I messed up when sharpening them, that should fix it. I'm also thinking I may have the blades set a little too low which would affect the feed roller pressure. Appreciate your help. Quote
Beechwood Chip Posted November 18, 2011 Report Posted November 18, 2011 Maybe the blades are OK, but they are mounted at different depths? If you had to grind more off one of them, they may no longer be the same. Quote
