Hi Marc
I'm a big fan of your videos and it was these very videos that re-sparked my love for woodwork.
I'm wanting some advice about which sized jointer I should buy. The two I'm stuck between are:
6inch with the below specs: motor 1hp 240v table length 1410mm table width 152mm rabbeting capacity 15 x 152mm fence tilt -45° to +45° fence stops -45° / 90° / +45° cutter knives three dust port 1 x 4" workshop footprint 1410 x 600 x 1310mm net weight 135 shipping weight 150
or the 8inch with these specs motor 1-1/2 hp 240v table length 1950mm table width 200mm rabbeting capacity 17 x 200mm fence tilt -45° to +45° fence stops -45° / 90° / +45° cutter knives three dust port 1 x 4" workshop footprint 1950 x 670 x 1310mm net weight 230 shipping weight 245
The dilema is this - I want to be able to have the cutting width of the 8inch but it'll mean that my workshop will be really squeezing for room. The 6inch will fit in a nice little spot but it doesn't have the cutting capacity. I'm in Australia and these two machines are the pick of the bunch so any suggestions are welcomed. I have a thicknesser as well which I could probably use (along with your tips from the jointers jumping video) for the cutting width issue.
Looking forward to your advice.
Regards Dale
I don't really know what to say. This topic has been discussed a lot. People who have upgraded from 6" to 8" jointers are very happy and wish they had just gotten an 8" when they started. But, a lot of people get a lot of projects done with 6" jointers. Only you can decide how much the space issue outweighs the larger capacity. Also, it depends on what sort of work you are doing. If most of what you do is little boxes, then a 6" will probably be fine. Finally, if you have hand-planes and a workbench, then you have the ability to flatten a wider board when you need to (once you learn how).
Hey Thanks for the advice.
No problem on the delay - now you have a kid life will always be busier than ever.
I went with the 8" - the biggest reason was I'm a quadriplegic in a wheelchair and the 8" has a longer bed on it which will make it easier to man handle bigger pieces of lumber without having to try and set up extra supports. Plus I get the cutting capacity. just means getting around the shop in my chair is going to be tighter.
I'm also hoping to jion the guild soon and start building along with you all.
Thanks again
  • Who's Online   2 Members, 0 Anonymous, 50 Guests (See full list)
