nikbrown Posted April 10, 2012 Report Posted April 10, 2012 Recently a lot of the cherry I’ve been working with has had a lot of curl and figure to it. As much as I love my Stanley Type 2 #604 the 45° bedding angle just isn’t steep enough to handle highly figured hardwoods. I wasn’t quite ready to drop a couple hundred $ on a new plane. A few years ago I bought one of the Hock Tools blades with the plan of eventually making a small infill plane. Allas, the blade had just been gathering dust on a shelf next to the stack of steel and brass. Having also developed an interest in Japanese style planes over the last few months I decided to make a high-angle pull plane with my Hock blade. True Japanese planes have a tapered blade that wedges itself into the body (Dai) due to a matching taper cut into it. (if you want to see the process that goes into cutting a Dai this page over on daikudojo.org has a nice photogallery ). The hybrid plane I made may look somewhat like a Japanese plane, but it’s construction technique is based on Krenov Style plane making. I made my high angle smoother out of quarter-sawn Wenge because I had it around, it’s DENSE, and I thought it would look cool I have a bunch more pics of the process over at my website if anyone is interested.http://digitalwoodworker.com/2012/04/10/making-a-hybrid-high-angle-plane-for-figured-woods/ Quote
nikbrown Posted April 10, 2012 Author Report Posted April 10, 2012 It takes ridiculously thin wispy shavings and leaves an amazing surface on very highly figured maple & cherry. 0 Tear out! I'm impressed with it! I should have done this long ago! Quote
Vic Posted April 10, 2012 Report Posted April 10, 2012 Nice! What width blade did you use? I have a Hock for My No. 8 Stanley jointer. I don't really need to put that into service. (null) Quote
nikbrown Posted April 10, 2012 Author Report Posted April 10, 2012 I have a number of hock blades that I use in all my bedrocks! they are amazing. This is one of the Hock Krenov blades. http://hocktools.com/PI.htm They are 3/16" thick!!! I used the 1¾ x 3½" #PI175. I should get one of the 2" wide ones and make another on bedded at around 48* for general smoothing work. Quote
Vic Posted April 11, 2012 Report Posted April 11, 2012 I think the No 8 blade is 2 3/8". You think that's be too wide for a high angle? (null) Quote
nikbrown Posted April 11, 2012 Author Report Posted April 11, 2012 It may be a little harder to push at that steep angle but it should be fine. I would make sure to get a Hock Cap Iron as well!! Those Hock Stanley replacement blades are only 3/32" thick. I think you would have problems with chatter if you dont put a good thick cap iron on it as well. Quote
Vic Posted April 11, 2012 Report Posted April 11, 2012 Yea, I bought a bunch when I made my first purchase. (null) Quote
