rodger. Posted April 15, 2012 Report Posted April 15, 2012 I camber my #4 smoother. Is cambering a good idea for a jointer plane (veritas - bevel up)? I will use it to both edge joint and to flatten tabletops. I think that cambering is a good idea for the flattening, but will it affect the edge jointing operation? Quote
pagel Posted April 15, 2012 Report Posted April 15, 2012 If you're planning to use the Veritas fence for edge jointing, it's probably not a good idea to camber the blade because you lose the square cutting edge. Otherwise, it should be fine unless you anticipate jointing 2-1/4" thick boards. As long as the edges you're jointing fall within the non-cambered part of the blade, you're good to go. Quote
rodger. Posted April 15, 2012 Author Report Posted April 15, 2012 If you're planning to use the Veritas fence for edge jointing, it's probably not a good idea to camber the blade because you lose the square cutting edge. Otherwise, it should be fine unless you anticipate jointing 2-1/4" thick boards. As long as the edges you're jointing fall within the non-cambered part of the blade, you're good to go. Should I just buy an extra blade? One for jointing and one for cambering? Quote
pagel Posted April 15, 2012 Report Posted April 15, 2012 Should I just buy an extra blade? One for jointing and one for cambering? Yes, that's the way I would go. Another $35.00 for the flexibility of switching between jointing and smoothing on the fly is worth it in my opinion. BTW, I'm currently using an old Bailey #7 that I love, but I'm seriously thinking about getting the Veritas Bevel-Up Jointer because of the fence, low angle, etc. Quote
PaulC Posted April 15, 2012 Report Posted April 15, 2012 I have the bevel up jointer, jack and smoother. So I took one of the 25 degrees blades and ground an 8" camber in it. Then I got the other two angles of blade for them. Gives me a full arsenal of blades for working wood. Quote
rodger. Posted April 15, 2012 Author Report Posted April 15, 2012 Okay, I'll grab an extra blade and camber one of them. Thanks for the advice guys. Quote
nateswoodworks Posted April 16, 2012 Report Posted April 16, 2012 Just a thought but you may just want to keep an eye out for an old Stanley or such, havve the Veritas hold whichever you use more (cambered or non) that way you can grab and go. Just a thought as it may save some time and frustration by not having to switch back and forth or worse-forgeting to switch back. Just a thought. Quote
