Water Based Poly mess up?
I think I might have messed this one up. I got in a little of a hurry when spraying water based poly floor finish on some stair treads I am working on. It seems that the finish is still a little soft, scrathes with a finger nail, and it has been 2 days. I sprayed (with my Earlex 5500) 4 light coats with about 45 minutes between coats, enough that it was dry to the touch. Do you think it will harden more if I leave it cure for a couple more days? I am using Varathane's waterbased floor finish. Seems like my test board are harder, but not sure if that is due to cure time or different finishin schedule (did just 2 coats with 8 hours between coats). Any thought or reccomendations? I want to make sure the finish will last for at least a little while before I go and glue the stair treads down ( I am applying them down on top of the existing construction grade treads.
Thanks
You said a hurry so I assume this is a customers house? If it is yours, then I would give it a few more days. Sounds dumb to ask since it seems you know what your doing but did you do all of your prepatory work the same on your test boards?
No, this is my own house, just was in a hurry to get the project done. I have decided to give them a little more time to cure and picked up on a different project for this weekend.
Yes, I did the same prep routine on the test boards, only difference was the test board got two coats of poly brushed on with plenty of time between instead of 4 spray coats quickly.
Just wondering...did you happen to thin the product? I'm not familiar with Varathane, perhaps thinning of the product, may of changed the chemistry causing cure issues or slow cure? Let us know if the finish has hardened up for you?
Depending on the weather where you live ( cold = longer dry times) it can take a few days for W/B to cure completely.
Especially if you didnt allow the previous coat to completely dry.
Did you follow the manufacturers recommendations for drying time?
Update - After leaving the stair treads to cure for an additional week they seem to be much harder and a finish that I trust to install. So lesson learned and on the second set of treads to finish I allowed at least 4 hours between coats, and that was in a warm and mostly dry garage (it was 90 and humid outside, but set the dehumidifer on full blast in the garage, which stays cooler since it is partly undergound, split level house)
  • 26,009 Total Members
  • Joseph b Newest Member ·
