Tiger Maple Kitchen Countertops - Help Finishing
Hi All:
I'm trying to finish large area of solid tiger maple kitchen countertops...trying to recreate the same finish as on the kitchen island. IMG-20120713-00716.jpg Pics attached.
You can see in pics below the countertop around the sink has little if any grain pop... the owner threw on an oil based stain (he said Cabot Fruitwood color) and called it a day. The sealant is pure tung oil (has to be food safe)...
YUCK! No pop, blotchy.
Again, the kitchen island looks great, but the other counter tops are awful in comparison.
My questions is about sanding/finishing.
I've got a 5" orbital sander and am thinking the following:
1.) 80 grit, wipe
2.) 100 grit, wipe
3.) 150 grit, wipe, apply water based dye (dark brown). Let dry.
4.) 220 grit to knock down grain.
5.) Apply dye (maple/light brown).
6.) Polish with 0000 wool
7.) Tounge oil seal (3 coats over several days)
I'm not a woodworker/finsher...just a motivated do-it-yourself-er...so I apologize in advance for the 1st grade mistakes in my thinking.
Any/all suggestions would be greatly appreciated!
Doug
Your method would be right if you had curly maple to make "pop". However, it appears as if you will not be able to achieve this since you don't have curly maple. You best recorse would be to prevent the blotching as much as you can. In which that case you want to avoid the absorbtion of the oil into the wood. You don't want to use a stain or oil without sealing the wood first. I like to use shellac, Zinnser "Sealcoat" first as the sealer. Then stain, then top coat. Yes, sand back the original finish first.
Thanks!
The wood around the sink is the same as in the island. Its just that you can barely see the striping in the maple in the wood that is around the sink area.
s
Calling the boards in the sink picture tiger maple is a real stretch.. To me, that looks like plain maple with some sections of curl. Maple can have varying amounts of curl along the same board.
A straight dye might pop what IS there a bit more, but keep the following in mind:
- You need to get an awful lot of the existing finish off. Pigment stains are carried by a varnish binder. The varnish has already penetrated the wood, and may prevent the dye from penetrating.
- The Cabot stains I'm familiar with are usually a combination of dye and pigment. What's on there should have popped SOMETHING, but the pigment would mute it. On truly figured maple, you should see more figure, even with the Cabot stain.
- If the counters are not solid maple, but some sort of maple plywood, you probably don't have enough wood to remove to allow dye to penetrate. Look for end grain. If you have no end grain visible anywhere, chances are, the counter is plywood.
  • 26,009 Total Members
  • Joseph b Newest Member ·
