I am still a rookie when it comes to these things and I was wondering if someone had a quick answer. I want to mortise a piece using a jig that has a 1/2" top. The mortise is 7/8" deep giving a total depth with jig of 1 3/8". The mortise is 5/16" wide so I know a 5/16" bit would be ideal, but how long should the overall bit be? 2"? Longer? Also is it ok to use a bit with a cutting length that is shorter than the total depth? Say 3/4"?
I think that you would be fine with a 1.5" or 2" bit. You are going to have to do it in multiple passes. You don't want to bury a bit that small, that deep. I was once told that the rule of thumb is to not go deeper than the diameter of the bit. But it really depends on the kind of bit and the material that it is made out of as well as the type of wood that you are using. You are also going to want an upcut bit if you are doing this in a router table. This is going to help with pulling the shavings out of the mortise as you cut it. This helps keep the bit cool and clean. Good luck, hope this helps.
  • Who's Online   1 Member, 0 Anonymous, 41 Guests (See full list)
