Finishing problem with specific plywood
Hi all, I would appreciate some advice with this finishing problem. I'm fairly new to woodworking, but can't understand what is happening with my latest project. here's the story.
I bought some red oak as well as 1/4" and 3/4" red oak plywood from a reputable local hardwood dealer a month or so ago. I built a bookcase with them, sanded everything to 180 and proceeded to finishing.
I applied 2 coats of Danish oil to all surfaces and found that it wouldn't take in certain spots in what looked like a woodgrain pattern, but it didn't match the grain of the plywood. You should be able to see the lightened grain in the picture I have attached.
I decided to live with this inconsistency and after giving 3 days for the Danish oil to dry applied an oil based wipe-on poly. After more than 3 days the poly is still tacky on the 3/4 plywood even though it set up in a couple hours on all other surfaces.
I can't understand what might have gone wrong as everything, the solid oak, 1/4" plywood and 3/4" plywood all were handled, prepared and finished the same way, and the finish has been fine on the solid oak and 1/4" plywood (and even on some cheaper 3/4" plywood I used on secondary surfaces.)
I'd appreciate any ideas, suggestions, guesses, anything that might get me going in the right direction and, more importantly, help me avoid having this issue again!
Unfortunately I think my plan for the bookcase (which I wanted to be done with last weekend) will be to wipe off what I can with mineral spirits, let it dry, and hope that a fresh coat of poly will set up right.
Thanks.
post-7676-0-21783700-1351777957_thumb.jp
My bet is the adhesive used to manufacture the plywood has pulled up close to the surface. Thus not allowing the Danish Oil to do its thing. Conversely, the Danish Oil has pooled in the deep grain pockets in the oak and has not fully gassed off. So when you come over top with your poly, the Danish Oil is still gassing off through the wipe on poly, causing it to remain tacky.
I think you need to let the poly do it's thing. It will eventually cure. Danish Oil can be tricky. Me personally, I let Danish Oil dry at "least" 1 week. I hear so many folks use that "magic" 3 day number and have problems.
I have a raised panel made of flame birch for a spice chest I am making. After 3 days of the Danish Oil drying. I hit the panel with a hair dryer and some oil come pushing back up to the surface from the curl in the birch.
-Ace-
Thanks Ace. I had thought it might be glue from the next layer down. I'm trying an experiment with a piece of scrap... I applied some Danish oil and see the same problem. Once the oil dries (tomorrow) I'm going to take a picture, then sand off the veneer and see if the next layer of wood has a grain pattern that matches the light spots. I'll let you know how I make out.
I also plan to put some wipe-on poly on an un-oiled scrap of the plywood and see how it dries. If it dries fine I know the problem was with the Danish Oil.
I still think it's a strange problem to have with only the 3/4 plywood, not the 1/4 plywood, not the solid oak, and not even the cheaper Home Depot 3/4 plywood I finished at the exact same time.
Oh well, hopefully I can learn something here.
Thanks again. Other ideas or things to try also appreciated!
  • 26,009 Total Members
  • Joseph b Newest Member ·
