SirGreggins Posted December 13, 2012 Report Posted December 13, 2012 Hey guys, i'm building the weekend wall shelf and have watched Marc's video several times but i still have one question as to how to cut the cut double of the back support piece. Do you cut one side then flip the piece over and register that freshly cut tapered side against the taper jig and double the angle to make the parallel cut? Can i cut one taper with the fence on the right of the blade, then move the fence to the left side of the blade and register the cut side against the taper jig now from the other side of the blade. I cant seem to grasp the concept in my head. Marc did it with a bandsaw which i dont have. I know i could use a straight edge down and use a circular saw but i want to know hot to this on a table saw. thanks in advanced. Quote
Jfitz Posted December 13, 2012 Report Posted December 13, 2012 What are you using for a taper jig? I can see a few ways to do this: - readjust the jig for twice the angle, as you mention - use the cutoff piece as a filler to provide the correct angle (put the cutoff in the jig and then butt the piece up against it). I would do this only if the cutoff and piece could be secured (clamp or double sided tape) to the jig - mark the center line on the piece and transfer to the jig; make the first cut; flip the piece over and use the center line markings to position it for the second cut Quote
SirGreggins Posted December 13, 2012 Author Report Posted December 13, 2012 i'll be using a traditional adjustable jig with a hinge. I think i'll play around with 1 and 3. Thanks Quote
CessnaPilotBarry Posted December 13, 2012 Report Posted December 13, 2012 I'd toss the hinged jig in the trash and attach your work to a rectangular carrier board with face clamps or double sided carpet tape. Since you can't see the back, you could also screw through the carrier, into the back of your stock. Hinged taper jigs give me the heebie-jeebies. A while back, I uploaded an example of one way to quickly build your own: Even if you don't build the jig, the images in the link above might add clarity to the carrier board suggestion. The basic idea is that the carrier (or jig) gets cut to width on the very first pass. After that, you simply align your intended cut line to the edge of the board (or jig), and the blade will cut where you planned. The jig is simply the carrier board idea with a miter bar to keep it going straight and to align it identically each time. You add / subtract / move the blocks as needed. Since you're only making one cut on each side of one board, you can simply align your marks and clamp or tape the stock down. Some versions of the jig skip the miter bar and ride along the fence. I like the repeatability and added safety of the bar. Using a carrier board is a great technique to understand, as it can come in handy in many situations. For example, tapers, cutting curved stock, putting a straight edge on stock without a reference edge, adding flats to curved parts... Quote
Eric. Posted December 13, 2012 Report Posted December 13, 2012 Here's what Barry is talking about. This one rides against the fence, and like he said, is cut to width on the first pass. After that, you can line up the marks on your piece to the blade side of the jig, then clamp down. You can add little blocks for repeatability if you're doing a bunch of a particular cut...you wouldn't need to in your case, just making the two cuts. This jig takes about five minutes to make... Quote
SirGreggins Posted December 13, 2012 Author Report Posted December 13, 2012 the only reason i was going to to the hinge is because it looked easier, but when it comes to safely making this type of cut i think you guys are right and sled is the better way to go. Thanks for the replies and CessnaPilot for the link. :-) i really appreciate the help. Quote
