cnc router thinking of buying small unit
hey was looking at the carve wright cnc router thinking of buying one. anyone have one and have a opinion? what are there limiations? how easy is it to pay off the cost of owning one of these machines. how easy is it for them to break down or wear out? how expensive is it to replace the bits? can a normal router bit be used or do they have to be special tips? what kind of dust collection do they have?
Since your shop is so small Dan, I think you need to buy one and keep it in my shop. Just trying to help you out a little bit. Heck, I'll even let you come use it when you want to.
you want me to buy the 80k unit and store it at your house? :)
im stressing about the 2k purchase for a desk top unit trying to decide if i will make money to pay for this.
The older carve wrights were a diaster plenty of horror threads to read through mainly though the spindle is its weak point sometimes the software did not recognize its position and drive its self on the z axis through the workpiece destroying spindle. The small work table also is a drawback. Have you considered the Fireball X90 with a 18x18x3 table is very generous
and the motors are actual trim routers. 1500.00 not a bad price either as all the parts are interchangeable and upgradeable.
Most of the serious cnc guys build an enclosure for the entire machine to operate in cuts down on the noise and controls the dust collection better. Not sure which version of the carve wright your considering but 28 of 54 amazon reviewers gave it 1 star.
only reason i had put much thought into a carve wright is someone on the forum has one and talks about the projects he makes with his. i had thought to get it just because of how clear and easy the system looks where i can just grab and paste images and then put it in the machine and have it print out the wood that i want to make with little effort. the carvewright software seems great but the tool itself looks like a pile of junk. not shure i want to spend 4-6k on a hobby tool when i can make a entire wood shop with that same cost.
can anyone else recemend any other brands or small cnc routers that i might want to look into.
i looked at there site does not look like they have as comprehensive or as easy a software for there cnc routers. in fact there programs looks rather simple in compaireson.
I had a chance to buy a carvewright last year for 800.00 after reading the reviews I passed on it and found the fireball series. The software makes the carvewright very appealing. The proprietary parts and small work area are the drawback. I would look at cost of bits and parts to maintain the carve wright and factor that in to your decision. You are correct the software is more time consuming and complicated.
I am an ex CNC sales guy. When I sold them, these machines started at 100K.
Software is king.
Second. Use the best and balanced tools on it. The vibration goes in the spindle and you end up taking everything out of whack.
Did I mention Software?
I have the Shark Pro Plus HD and have had no problems with it. I agree the software is everything with these machines and the Shark uses software from Vetric called VcarvePro. I wouldn't say the software is complicated but it has many features to get use to but the learning curve isn't too steep. The local Rocklers are starting up user groups for people to get together locally to help each other out. The system uses a standard Porter Cable style router and uses standard bits that cost $20-50 on average. As far as breakage, there isn't much to it. it's run by 3 servo motors and a control box. You can by replacement motors from the manufacturer for about $50.00 each if you needed to. I think your more apt to burn out your router before anything else. Depending on the detail and size of the carving, your router can run for a couple hours non stop. I've had to replace the brushes on mine a couple times but the thing still runs fine. On the smaller units (original shark) they use the Bosch or Dewalt Palm routers and these where burning out after 100 hours or so (problem solved with an extended warranty from HD or Lowes). As far as payback, if you got into making signs you could probably pay for the machine in a few weeks. With the software you are not limited to only making signs the size of the bed. The software has a feature called tiling that lets you carve a large sign in pieces and then you can join them afterwards (the accuracy is phenomenal). You can also customize things for people as well and I seam to get a lot of request for things like that. Check out Vetrics web site as they have project ideas as well as software tutorials plus you can download a trial copy of the software. There is also a site they you can buy images that you just need to create a tool path for Vector Art 3D. The average image is about $25 but these are really complicated things you could never draw yourself unless your an artist. I don't have my machine encased but I do have dust collection. Basically it's a brush that creates a chamber around the bit with a hole in the top for the hose and gets about 99% of the sawdust. Without one its a big mess!
All in all I'm very pleased with it. The original Shark is just under$3000.00 and the one I have is about $3900 but I figured it was worth the extra money to use stronger routers. This may be more than you want to spend but I think it's worth it at the end of the day.
I own a carvewright and its not as bad as people make it out to be. The only problems i have now with it are fine dust getting into the bearings. The software is super simple simple to use. Dont worry about the table size cuz you can stuff an 8 ft board in it 14 inches wide. Check out the forum because they are a very tight knit community just like here. Any more questions let me know.
-Jason
