calmari Posted January 19, 2013 Report Posted January 19, 2013 I am having problems getting my blade aligned square to the miter tracks on my Rigid 3660. I was swapping out my blade and noticed that the splitter wasn't parallel with the blade, did a little more checking and found my blade was out of square with my miter tracks. It is absolutely kicking my butt trying to get this blade square. For this saw, squaring is done by adjusting the trunnion via a lever at the rear of the table which is supposed to move the back of the blade left/right. The problem that I am having is that when I adjust the lever it shifts not only back of the blade but the front as well. I am using the combo square method Marc demonstrated in his T/S setup video. I set the square to just barely kiss the blade at the front, then take the same tooth to the back and check the distance and then adjust the trunnion at that point. When I get it adjusted in the back I check the front again and the front has shifted, probably 1/32 of an inch. I got the blade the closest I could and then tightened the trunnion bolts. Then it got interesting. I went to check the blade bevel stops and couldn't tilt the blade past about 15 degrees without it binding up. I put the trunnion roughly back to where it was before and was again able to tilt the blade. but the blade was back out of square. At this point I am at a loss. I bought the saw used a couple of years ago off CL and hadn't had any problems with it until now. Anyone happen to have any experience with this particular saw and can offer some advice? Quote
Grain Guy Posted January 19, 2013 Report Posted January 19, 2013 Yo dude I have the same saw I used a dial caliber that made the job easy and accurate. It sits on two cylinders in the track. Also cuts out readjusting the square after every tweek. The only thing I can think of with the bevel issue is to loosen the locking lever. I know on mine that the farther you need to bevel the more I have to back out the lock. Good luck man Quote
calmari Posted January 20, 2013 Author Report Posted January 20, 2013 Finally got it aligned. I took the motor off to reduce some of the weight on the trunnion and then loosened all the bolts and started from scratch on the blade alignment. Got it dialed in and then locked everything down tight. It was still binding when I tried to bevel, I ended up taking my Dremel to the race to grind the spots where it was hitting slightly and now it moves perfectly. I need to have my head examined, tho...at one point when I was about ready to throw in the towel my wife started asking questions about getting a new saw, and I told her that I would keep on this one some more. Quote
tdale51@yahoo.com Posted January 21, 2013 Report Posted January 21, 2013 when the wife suggests you buy a new tool you buy a new tool!! And quickly before she comes to her senses! Seriously, congrats on your "stick-to-it-ivness" and solving your problem. Quote
