Opinions on MiniMax 300 Smart
Anybody have experience with the CU300 Smart?
http://www.minimax-usa.com/index.php?page=shop.product_details&flypage=flypage_bs.tpl&product_id=27&category_id=2&option=com_virtuemart&Itemid=35
I always dismissed combo machines as a compromise, you know, they do lots of things but none of them really well. I've been told the CU300 is an exception. I don't really mind the inconvenience that comes with combo machines but I don't want the frustrations that come with lesser quality or poorly designed machines. I know MM has a great reputation but I don't know if that extends to the combo machine. Thanks all.
Haven't used a 300 Smart but based on the other MiniMax equipment I've been lucky to try, I'd say it's a good purchase.
Haven't found anything negative about it, some folks on another site seemed a bit biased against combo machines but not this one in particular. Few folks that used them or had them said it was a great machine. I'll see what else I can find out.
Question number one: what is your familiarity with Euro-style saws?  I’ve owned/used both ‘US’ and ‘Euro-style’ saws and each has their own way of doing things.  Not that one is better than the other, just different…  If you are comfortable with the Euro saw, then fine.  If you haven’t used one, than I would strongly suggest you give it a try before dropping $20K on this puppy.  If you don’t have much experience with either, then you’ll be fine.
Question two: Experience with combo machines…  It does save space and $$, but imposes more structure to your workflow…  I tend to group my operations for every project anyway, so I’m OK with that, but the imposed structure might drive a more ‘free-wheeling’ type a bit crazy…  When I was on a combo machine, I would always mill an extra stick; make an extra rail/stile, etc to avoid reconfiguring the machine if something went wrong downstream… I still do this today...  a bit wasteful, but it sometimes pays-off..
Because some folks get tired of combo-machines, you sometimes get a good deal used from a hobbyist.
As far as MiniMax itself, I believe they are now a separate entity from SCM (but held as part of SCM’s parent).  I also believe the MM 300S is a re-branded SCM cu300 out of the Rimini plant.  Historically, SCM has a good reputation and considered one of the best mid-range units.  One advantage of MiniMax is parts availability through SCM – they are considered quite well in that regard… reliable parts availability in the US is critical for Euro tools...
My experience with Euro tools is limited to Felder and Griggio.  I no-longer use a combo machine, but still retain some Griggio and Felder stand-alone machines.  The rest of my shop is PM.  You will appreciate the build-quality for many years to come…
Make sure you get setup thrown-in with the purchase price:  A, the units are heavy -- and B, the last Euro-machine I got only had a manual in Italian :)
PS: You’ll need some metric tape measures…
There are two types off saws euro vs us are not them. Conventional vs slider are the two types. PM makes a slider as does grizzly, the quality differences between the pm and minimax is night and day. The shaper on the minimax runs alot smoother with a much smoother better machined lift mechanism. The jointer / planer uses tersa cutters that are superior to even helical cutter. The J/P side runs smoother than the best that PM. has to offer. The lift mechanism is more accurate and the tables are built better. The best part is no snipe. They did it right when it comes to the planer.
If you generally work in an efficient manor then a combo will fit the bill just fine. If your a one man production shop then I'd stay away from combos. If would have known my health was going to slow me down so soon after rebuilding my shop I would have got the Mimax or felder combo. Demo the minimax i think you will be very surprised.
Don
Thanks all, very helpful comments and everything I have found is positive. Now we'll see how the discussions on cost goes.
