Need help with a motor. Motor is old. It's my 200 gallon warehouse compressor motor. It died so I pulled the caps out and tested. No problem one bad cap. I drew a diagram before pulling the caps but didnt get it put back together before losing the diagram.
It's an old doerr single voltage 5 hp reversible running ccw. Single phase.
Attached is the motor plate. There are three wires in the box leading to the motor windings, no markings on any maybe a t6 on one but can't tell for sure. There are 4 caps. I assume 2 start and 2 runs.
Any help would be appreciated.
Good luck!
I started taking pictures as I disassemble any tool. Write labels on tape for wires and labels on post it notes inside ziplock bags for screws and small parts. Not much help to you now.....
Oh boy, a challenge...
I've got some stuff in the shop to finish this am, but will dig-out one of my old texts this aft...
Four caps you say?  Interesting.  I think you are correct, start and run caps.  The starts should be about 200+uF electrolyic  and runs should be about 30uF film.  If you have a decent VOM in the shop, we can determine the start winding and with the cap ratings we can go from there...
Thank you I'd really appreciate it. I'd rather not have to take the motor off. Thing is heavy and my fork is broken and I need the impact to fix the fork or the fork to lift the motor, pretty much screwed. :) I do know where two of the wires go but the third and jumpers are a mystery. Ill take some pics of the caps. This is what happens when you procrastinate I guess.
Tops of the 2 15's /370 vac The cap on the far right failed and the black left on has a scorched terminal so I figured I should replace anyways. The 4 caps are factory except one of the silver one which was replace about 10 years ago.
Inside capacitor box. All wires are black with no markings.
Left wire goes to left silver cap. Right wire goes to left black cap. Center wire is a mystery but has to be one of the two on the left silver cap. CCW from the front.
i get the same on all three leads with L1 and L2.
L-R per the picture of the capacitor box.
.3 , 2.5, 6.5
This is going from each lead in the capacitor box to the mag start motor side connections L1 and L2. Mag start is off and of courase no power applied.
  • Who's Online   1 Member, 0 Anonymous, 43 Guests (See full list)
