sjeff70 Posted April 11, 2013 Report Posted April 11, 2013 Tersa seems to be the standard in the East. For us peons with jointers and planers in the U.S. (Delta, PM) you have to upgrade to the TERSA R2000 SYSTEM, or just buy the Tersa replacement knives for your straight knife cutterhead. The TERSA R2000 SYSTEM is replacing the entire shaft like you would with a shelix for example. But which floor jointer and planer would one need without taking the machine apart to replace the shaft? More importantly, if you don't have access to slide new blades on, there's no point putting one of these shafts on is there? Unless it was easy to replace the cutterhead shaft...does that exist? If I buy a used jointer and planer with straight knife cutter heads, in order to use the Tersa replacement knives I have to be able to slide the knife onto the cutterheads. Which American jointer and planer allow me to do that? Lastly, why does Tersa offer to modify a TERSA R2000 SYSTEM shaft for your existing jointer or planer if you have to take the shaft out to replace the blades? Do I understand properly? I searched for a long time and it became apparent that the little information that does exist out there is very conflicting. Quote
dwacker Posted April 11, 2013 Report Posted April 11, 2013 You are correct. Jointers not planers. Might as well just go minimax or felder. Definatly not little machines like 8" jointers and 15" planers way to expensive. I checked on a terminus jointer head in Jan and they only made them for 12" + at that time. Even though I have a 12" the cost was to high. Quote
sjeff70 Posted April 12, 2013 Author Report Posted April 12, 2013 PB, Yea I know I'd love to have that kind of cash for a jointer. Have you seen this catalog? http://www.magnate.net/catalog/2011%20Magnate%20Planer-Jointer%20Knife%20p80-84.pdf They offer replacement knives for older American jointers and planers, (Delta and PM). They're saying their knives will work on those machines. For instance they offer a set of 3 replacement knives for a Delta DJ-20 jointer. Are they saying it is easy to replace knives on a DJ-20? Now you look at the TERSA R2000 SYSTEM and at the top they say they can modify their shaft to fit your jointer. How difficult is it to replace a shaft on a jointer? Some easier than others I'm sure? I'm trying to determine which jointer I should be looking for. Quote
dwacker Posted April 12, 2013 Report Posted April 12, 2013 The heads are easy to change on a jointer. Just looking at my PM 12". Looks like you can easily slide a blade out that is about 3/4" wide. 3/4 is the depth of cut so cut depth vs blade width is something to look at. Second if it was wider the rabbet shelf is removable so not a big deal but Im not sure that is the case with all jointers. Id look through the online owners manuals. Id probably just call them and ask what jointers they sell the terse for the check the specs to see how difficult they would be to remove. Quote
sjeff70 Posted April 12, 2013 Author Report Posted April 12, 2013 That's good news I think. I looked at new machines to see if any had Tersa but I didn't call. Websites don't tell all. Looking at owners manuals is a good idea. First ones I'll look for from the Tersa PDF, the 8" jointers: Delta DJ-20 PM 50 PM 60 These jointers are easiest to find. I will email Tersa too and ask them. I didn't know how involved this would be so thanks for giving me a place to start. The west is really behind on these machines. We've lost a lot in the U.S. Quote
sjeff70 Posted April 12, 2013 Author Report Posted April 12, 2013 Looking over your last post, when saying it's not worth it for an 8" jointer is the money better spent buying a wider jointer? Does it make sense investing in Tersa for both jointer and planer? Planer it makes good sense of course. Quote
