Front top section too wide... Help?
Hello, first post here...
So I'm new to woodworking and after building a dining table and several other small pieces of furniture during the first month of this new hobby I decided to go with the Benchcrafterd Split-Top Roubo as I quickly realized a pair of sawhorses just wouldn't cut it...
It all started fine and have been feeling confident with my progress... I have assembled both top sections and have started working on the legs... Due to lack of space I will not work any detailed work on the top until the leg structure is finished. However, after going back to measure the timbers, I realized the front top section is 1/16th too wide clocking in at 8" instead of 7 15/16"... At first I thought it wouldn't be an issue (remember: newbie), but then I started going over the plans and figured it was more of an issue with the tail vise and the centering of the dogs (I intend on building square dogs)...
My question is how big an issue would this 1/16" be? Should I try and rectify the whole timber, or maybe just mill a step in the length of the tail vise? Or just leave it as is?
All input welcome!
Cheers
pw
I'm kind of confused about why it's a problem.  The only difference it will make is the size of the gap between the two slabs...yours will be 1/16" smaller if you follow the plans when building the base.  If you make your side stretchers 1/16" longer, the issue is resolved...your bench will now be 24 1/16" deep instead of 24", and the gap will be the recommended dimension.
As long as your front laminate is 1 1/2", and your dog strip is 1 3/4", nothing else has really changed for you...It's been a while now since I built mine, but I can't think of any other reason it would pose an issue.
I agree with Eric. As long as you consistently use the front face of the slab as your reference when making all measurements for the tail vise, you'll be fine. I think that's the process that Marc used in the videos anyway, though my memory is fuzzy. Some folks even eliminate the split top and have one deep slab. Keep us posted in your progress, and welcome to the forum!
Ha! I guess you're both right... don't know why I started visualizing the tail vise dog 1/16 off-center the rest of the dogs...
I guess it's easier to make the stretchers 1/16th longer than the gap stop 1/16th narrower...
Cheers and thanks for the help guys.
