Finish chair help
I recently stained a chair using watco danish oil stain and I did not not pre-seal it (newbee) and I got some blotchy spots. I did about 4 coats of the danish oil. Would it be ok to use a gel stain on top of the danish oil to make it darker + get rid of or make the blotchy spots less noticeable? If so do I use a pre-seal on top of the danish oil? Do I just go ahead and lay a gel stain on top of the danish oil? If I do apply a gel stain should I use a clear top coat or could I go without? I dont want to restrip the chair if I dont have to. As you can tell I am a beginner. I did some research but could not find answers to my questions. Thanks!!!
Theoretically you can you a gel stain as a glaze. You don't need to condiftiom because the wood is already sealed. Just lightly scruff sand the last coat with 320. And you will need a clear coat on top of the stain. A must. Let the stain dry thoroughly so it's not tacky. Overnight perhaps.
You can also get another can of Danish oil that's darker. You can also mix oil based stains with your Danish oil though.
Thanks Tkf. I am going to go for it. I did test it on a piece of wood and it seemed to work. I am wondering about the blotchy spots and how they will react to the gel stain.
The danish oil sealed the wood. It shouldn't be a problem. If your still worried and have shellac on hand wipe some on and apply another coat of oil.
  • 26,009 Total Members
  • Joseph b Newest Member ·
