jrh0558 Posted September 27, 2010 Report Share Posted September 27, 2010 I'm trying to install the Rockler steamer trunk hardware but the corner pieces don't fit as well as I was thinking they should. Does anyone know if I need to bend the tabs of the corner pieces in order for them to fit correctly? Thanks for any help you have. John Quote Link to comment Share on other sites More sharing options...
Lawrence Brown Posted September 27, 2010 Report Share Posted September 27, 2010 Looks like it's maybe just the point on the corner hitting the inside of the hardware? If that's what's happening, you probably just need to slice off the corner to round it off a bit. Make a test corner in some scrap and try it first! Don't want to ruin all that beautiful joinery. I know some of the Rocklers have display pieces set up. I don't know if you got yours locally or on the net, but if there's a store near you, maybe bring in the hardware (and a sample corner if you want) and compare it to theirs or ask them how it's supposed to fit. Quote Link to comment Share on other sites More sharing options...
iSawitFirst Posted September 28, 2010 Report Share Posted September 28, 2010 It looks like the point of the corner needs to be in the center of the "dome". I'd say bend the tabs to accomplish this. Quote Link to comment Share on other sites More sharing options...
Lawrence Brown Posted September 28, 2010 Report Share Posted September 28, 2010 From what I can see on the Rockler site and reading the single review there, it looks like these work better with radiused corners. All your corners are 90 degree. that extra bit of width on each of the edges may make it not fit correctly. If you want to keep the sharp corners, these may be better: sharp-edge trunk corners If I'm not explaining the difference well, I can elaborate. Interestingly, these are also from Rockler, just through the Amazon store, so maybe you can get your money back on the others and they can order the right ones for you. If you do go through Amazon, don't forget to use the Wood Whisperer link. Hmm, I wonder if that gives both TWW and Rockler some kind of reward... Quote Link to comment Share on other sites More sharing options...
jrh0558 Posted September 28, 2010 Author Report Share Posted September 28, 2010 Thanks very much for your feedback. I'll try rounding a corning on a test piece and see if that does the trick. John Quote Link to comment Share on other sites More sharing options...
