PM1900 Dust Collector – Collector Bag Leaking
I have a Powermatic PM1900 and both collector bags are leaking fine dust. Is anyone else having this problem? The unit is equipped with canister filters on top and collection bags on the bottom which are heavy clear plastic. There are no holes in the bags and I have installed them multiple times to ensure they are on correctly. PM technical support did not have any ideas other than to install the bags according to the manual. I must be doing something wrong installing the bags or these units leak fine dust by design. I can see traces of dust leaking where the bags are secured to the steel housing by the fabric covered spring steel rings. Any ideas how I can eliminate the leak?
Go to your local borg and get some weatherstripping tape, as thick and wide as they carry. Apply the tape around the steel housing of your dust collector where the band clamp sits. The weatherstripping tape will provide a tight seal, and your dust leak problems should go away.
Eventually you'll have to replace the weatherstripping tape, but that's a trivial thing to do.
Ditto what Wilbur said. I did the same thing years ago on my delta d.c. Just a 1" wide roll of the grey weatherstripping sold at the borg, unfasten where the plastic bag sets, apply and smooth down with some force, don't try and stretch the tape to conserve it as it will rebound and end up pulling itself off of the surface you adhered it to. Put your bag back on and clamp 'er down :-)  If you build yourself a Thien separator, you may never empty that bag again... I haven't in years!!
  • 26,012 Total Members
  • JAR Newest Member ·
