30+" wide crosscuts on a benchtop saw?
Why not! My contractor saw is awaiting pulleys and a new belt to tame the vibration. God, I hope that works otherwise I wasted a bunch of time and money not only on the belt/pulleys but on building a saw station... we'll see.
My benchtop saw is a ryobi bt3100 similar to some craftsman line saws. The rails are extruded aluminum, with channels in the underside and rear faces that accept a flat oblong rectangular metal plate that is threaded to accept a stud. The saw had the option of converting to a wide kit by using this plate to join two rails together to allow crosscutting wide panels.
My woodworking marathon day started with the need to breakdown some panels for the cabinets I am building, but the saw didn't have the capacity. I also didn't have the special plates on hand, so the day actually started with some welding. The next picture shows the setup. Not the most stable nor accurate, there is some flex in the rails since they are not supported completely and that causes the fence to not lockdown accurately. I ended up recutting the panels several times in steps to get them within a tolerance to build cabinets. Time consuming.... can't wait to be set up to work properly!
d92e384b-73e6-44b9-a151-e33d9c4a0c43_zps
Parts of 4 cabinets milled up with joinery cut.
The sun setting on a good day's work!
Awesome ingenuity!  Before I opened the thread, I was concerned I'd see a fence board clamped to the wide stock and you flipping the benchtop tablesaw up-side down against it...
lb
My thoughts were similar. Congrats on the completed work :) there is nothing better than fixing a tool and completing your work in the same day.
