almost done with project...
So I'm building a jewelers bench for my wife. It's made of ash and with walnut accents. I'm going to use pre mixed amber shellac on the base, how many layers do you think I should use? I'm going to have to finish it in my basement, because I work in an unheated garage in Vermont. My other option is to ,if he's ok with it use the boat builders shop a few houses down. I'd like something durable but will take abuse on the top. I wish I could post a picture here but the mobile version isn't so friendly for that.
Thanks in advanced...
-Justin
I don't know if there's any true reason behind it, but I always just do 3 coats of shellac. Could be wrong for some people, but works just fine for me.
Another bonus of shellac is you can use shellac in cold temperatures. I've sprayed at 30 deg temps in my garage and bring the piece into the house to cure with no problems. Ash is similar to oak and has deepish grain. So if you want dead flat smooth surface? Keep going with the coats till the grain is filled.
-Ace-
My apologizes, thought I read the based is only to be shellac and how many coats do you think I should apply? As for the top. I would use a good oil finish like General Finishes seal-a-cell, something thin and close to the wood.
So the top is for making jewelry on....use of a small torch, heat, solder, wire, lot of scratches to the surface, not sure any finish is going to stand up to that abuse. So that's why I suggest seal-a-cell...something thin to color the wood or just use shellac to the top and repair the top from time to time. Or do the whole piece in seal-a-cell.
-Ace-
Yes I was looking for something mostly for the other parts other than the top. I know the top will take abuse in all the forms mentioned above. I may just shellac the top. But the other parts, general finishes arm-r-seal?
  • 26,009 Total Members
  • Joseph b Newest Member ·
