Band saw brake
I saw an industrial band saw today to cut foam rolls, about 36" in diameter. After each cut, the guy had to wait for the blade to stop.
Can you add a brake to stop the blade with a switch or foot pedal?
The foot pedal is pretty easy mechanically. Someone with metalworking skills could fabricate what you needed pretty easily, I'd guess.
Here are shots of mine. Pedal is on the side; you see the slot it goes into and that the articulating arm is flat bar stock that's vertical so it has clearance inside behind the lower wheel:
In this shot, you can see the spring attached to the arm; again pretty simple to add in:
This is a shot through a hole in the lower whee. The articulating arm's attachment point is to the left above the wheel's center. In the middle of the arm is a curved piece of metal covered in tire rubber. You're seeing the curved profile of that metal and tire:
Last shot, this lets you look behind the wheel; The wheel has a large hub attached to it where the drive belt goes.  The brake you saw above is on the inside of that hub (the belt is naturally on the outside):
Mine's only an 18", but you can stop it pretty quickly with the brake.  Seems like something a metal guy could do pretty easily; heck I don't think it looks that hard.  Hardest part is removing the lower wheel; once that's off, it's all clear.
Maybe depends on the saw and the usage. You would not want a friction brake on a big saw that got shut down frequently. It takes a lot of force to stop bigger cast iron wheels. Even at moderate use I burn through friction pads twice a year on a 24" saw. With heavy use on a 36" you could go through friction pads weekly or quicker. For hobby use friction pads may last a life time.
My company has two of those saws for cutting foam rolls.  Not sure about if they have brakes - I'll have to ask.  I do know one has a 25' blade and the other is longer than that.
  • 26,009 Total Members
  • Joseph b Newest Member ·
