Veritas Plow Plane - Can't get tongue blade to work.
I have the Vertitas plow plane, along with the wide-blade conversion kit. I have spent a lot of time trying to figure out how to use the 1/4 tongue blade.
I see that the instructions say that for the 1/4 tongue blade the "only possible depth setting is 1/4". In the attached close-up photo, the blade is adjusted for a 1/4 inch depth. However, the integral depth stop interferes with the body of the plane. I cannot retract the blade any further than shown, and the blade is sticking out way past the skate.
I don't understand what I am doing wrong. I have been able to install the wide blades without any issues, but this integral depth stop doesn't seem to fit.
Can anyone explain what I need to do? Am I missing a step in the setup?
post-14451-0-87757200-1388894867_thumb.j
The depth stop should slide toward the skate. This will make room for the blade to be retracted properly. You should only have a minimal amount of blade protruding beyond the skate.
To clarify, the depth stop on a tongue blade is the adjustable piece on the blade with the screw, not the regular depth stop as used with a normal grooving blade.
Mel, I understand that. But then I wouldn't ever be able to set the depth stop to 1/4 inch to create my 1/4 inch tongue. According to the instructions, the depth stop on the 1/4 tongue blade should be capable of that.
The integral depth stop on the blade is used instead of the regular depth stop. Yours looks like it's about an 3/4 or an inch away from the end of the blade. Adjust the integral stop on the blade with a ruler. The edge of the blade to the bottom of the integral depth stop should be 1/4".
Awesome Mel, that video was the ticket!
Excellent! I'm glad you liked it!
I was measuring the integral depth stop as I show in this photo. This is wrong. I thought that matched the instructions in the attached drawing.
I figured out now how to do it. Instead of measuring the depth against the bevel angle, I need to measure while accounting for the angle that the blade is bedded in the plane.
Mel, I don't know if that is what you meant. When I read your statement, I thought you just meant to measure the straight distance along the blade, without accounting for the angle like in the attached drawing.
post-14451-0-00295500-1388898981_thumb.j
post-14451-0-03456700-1388898984_thumb.j
Yep! Measure it how it sits in the plane. Meaning from the flat part of the bevel to the start of the integral depth stop. Like the picture. :)
Glad it worked out!
