Guys, I sure would like some help!
I have a 110V/1.5 Hp single stage steel city dust collector.  This unit is rated at 1200 CFM and has a 1 micron filter bag.   What I would like to do is convert this unit into a dual stage system using a cyclone.  If I were purchasing new today there are several "off the shelf" dual stage systems that are really nice.  However, I have the single stage unit with limited hours of operation so I figure it wise to use what I already have.  I have a limited amount of ceiling clearance since this shop is in our basement.  I just can no longer put this project off if I am going to continue to woodwork in the house!
What I am hoping is that there exists some previous knowledge in doing something like this (conversion of a steel city unit) and some typical do's and don'ts.  I would like to hook this up to what I believe to be a 5" main trunk and drop it down using 5 inch pipe and adapt that to several stationary tools i.e. scms, table saw, jointer, planer, band saw and a sander.  However, I am unsure on what to use for piping.  I am thinking S&D PVC and "Y" connections and all turns using 45 degree elbows so I don't have any acute 90 degree fittings. I would like to limit the amount of flex hose as I know that lowers the efficiency greatly of an already lower end cfm.   I will have to ground the system since I am using plastic which is fine.  Any help pictures etc would be greatly appreciated!!
Paul
May I ask why you want to hinder the unit with a cyclone? Also in the real world you don't lose too much with short runs of hose. Truth is with small air handling capacity nothing gets it all. The best you can do is to position the hoods in direct line of fire. Chips will find their way onto the floor period. I'd guess that 10% on lots of operations goes uncollected. Cyclones will reduce the airflow and are not needed in small spaces. You gotta empty something so just empty the bag and use your time and money to build something or buy some extra tools! :) good luck.
Steve
