Jfitz Posted January 20, 2014 Report Posted January 20, 2014 I got a carbide BS blade last spring (part of a larger order) and only now just started using it. Looks like it's not the greatest blade - it's a little 'off' at the weld, causing one or two teeth to stand proud of all the others. it gives a noticeable 'tick tick tick' sound as those teeth catch the wood. I contacted the vendor, and they said it's out of warranty so I can't get it replaced. Should I try to grind down those teeth with any sort of regular grinding bit on my dremel? or do I need some sort of diamond bit? Quote
Popular Post dwacker Posted January 20, 2014 Popular Post Report Posted January 20, 2014 If they want to be jerks about it buy another blade. Stick the junk one in the box and send it back as defective. 3 Quote
