My dad picked me up a used dw733 for my birthday.  It runs nice, but I think there is something wrong with the outfeed roller.  When I run a board through the middle of the blades, the board tends to spin away from the height adjustment side and the board does not get pulled out past the blades.  When I run a board on the side opposite the height adjustment, the board doesn't spin, but it is not pulled out past the blades.  If I run a board through on the side nearest the height adjustment, the board runs just fine.  It passes all the way past the blades and does not shift when it comes through.  I have cleaned the outfeed roller so I know that is not the problem.  Has anyone ever experienced this problem?
Sounds like the head is out of level.  On the bottom of each of the 4 screw posts is a nut that you can loosen and manually turn the columns to adjust of head height.  Take a small block of wood and lower the head unit down until it just touches one of the corners, then compare the height on each of the other 3.  Adjust as necessary :-)
Hope this helps!
That did the trick.  I checked the cutter head alignment first.  It was off by about 1/32", not what I thought would be enough to cause as big of a problem as I was having.  I can adjust that better with the table that I have built for it.  I checked the blades, and one of the blades wasn't seated properly.  Not sure how the one side was set so bad, but I adjusted using the knife setting jigs that came with it.  I ran a board through and problem solved.  I do need to either sharpen or replace the blades, but no more problems like what I was having.  I knew if I posted it here that I would get some answers.  Thanks for the help.
  • Who's Online   2 Members, 0 Anonymous, 56 Guests (See full list)
