Makita Miter Saw Blade Movement
I've notice lately that I'm not getting clean cuts using my miter saw. It's hard to describe but it looks like a cut you might get if you saw part way through the board - lift the blade and then drop the blade to finish the cut. There is a circlular mark left on the cut portion of the board. I always use the miter saw clamp to avoid wood movement.
Ok, with that said -  I noticed that when I grab the blade it has some side to side movement. Approximately 1/16th of an inch of movement. I checked to make sure the blade was tight and it is. As this is the only miter saw I've ever owned I have nothing to compare it with. It doesn't seem normal that the saw blade should move side to side at all.
I will add that this saw is about 6 years old and I've used the crap out of it. Do you think it's just worn out and needs replaced?
Thanks for any help or suggestions.
Is it a fresh sharp blade?
Does the slop you're feeling feel like it's coming from the bearing?
Thank you for replying.
The blade is a sharp Forrest blade. That was my thinking - bearing is wearing out. Not hearing any weird noise at start up or shut down.
Well, as I don't know much about the Makita chop saw, best to let someone who owns one to chime in..
Slop in the bearings and loose pivot joint can both cause that sort of marks. I've got an old huge Makita miter saw that sounds like a jet engine spooling up. If I let it get up to full speed and gently make the cut its still pretty smooth. If I get in a hurry I see those same marks.
