Pwk5017 Posted December 9, 2015 Report Posted December 9, 2015 I purchased a bundle deal this week, and am wondering what accessories I should add to make the most of these tools. The original owner passed away and his family listed the items for a good price, which was sweetened when I offered to take everything that was green. Now I have a TS75, OF1400, and an OF2000--which I had to look up because I hadn't heard of that router. With good reason, the model was discontinued a couple years ago before I was even considering this craft. The TS75 has the blade and other typical included accessories, but it has a parallel guide with it and no tracks. OF1400 appears to be standard factory kit. The OF2000 looks like he bought every available edge guide, track adapter, bushings etc. Clearly, the TS75 needs a track to perform to the best of its abilities. What track(s) to buy though? It typically comes with a 75" rail, which is odd to me. 75" rail isn't long enough to rip a sheet of ply or mdf, and it seems like it would be awkwardly long to use on shorter cuts and crosscuts. I would appreciate people's inputs on what lengths they would prefer to have. Currently, I am leaning towards a 42"-55" rail to handle all my shorter cuts, and then add a 55-75" rail with a connector, or go whole hog for the 106" rail. That long rail is so expensive for how much I would use it though. 95% of my work is with solid lumber, so I would only use that long rail for straight-lining big slabs/boards and for cleaning up glue ups that are over 36-49". I have a jessem mast r slide that can crosscut in the 0-30" range pretty comfortably. Over 3' and the slider sled is dangerously disengaged from the sliding bearing table, which induces some slop and the chance you pull it out too far and drop the whole thing on the floor. Also, it brings up why I wanted a track saw to begin with; muscling a huge workpiece to the table saw to trim up an end is a heck of a lot harder than taking a 13lb saw to the workpiece. Honestly, if I didn't know I have a 65" cut in my immediate future for a recent commission, I would be getting the 55" and be done with it. I still might do that and see if someone in the Pittsburgh area would let me borrow their 75" rail to make my two cuts I will need to make in early January. Router time, went off on a rant with the saw tracks. My plan is to keep the OF1400 and sell the OF2000. Would this be a tragic mistake on my part? It seems like an overly large router, and it wasn't considered one of festool's greatest accomplishments. Still, a fine router by all means, but I see the OF1400 being my main workhorse and the OF2000 sitting in a corner except for the times I need to plunge a bit deeper or something else. I have the big PC in my router table, and two bosch 1617 combos. Any chance of using the OF2000 edge and track guide with the OF1400, or are they specific to each machine? I am hopeful that the 2000 will cover most of my new accessory purchases. For the OF1400, what adds are suggested? It seems like the edge guide and guide stop for tracks are mandatory. Am I overlooking anything for that one? I look forward to getting to know the tools better and their capabilities. I think I need to sit down to a couple hours of youtube videos to understand how to best implement them. Going to need a CT unit sooner rather than later, I think. Quote
