Need Help Troubleshooting Grizzly Cyclone G0441
Hello,
I currently have a Grizzly Cyclone, G0441.  I have had the machine since 2012, and it has worked perfectly.  We recently moved, and I have setup my shop in our new home.  I recently finished assembling the cyclone, and the dust collection ductwork.
In our previous setup, I would use clear lawn and leaf trash bags in the dust collection drum.  I have had no problem with this in the past as the Grizzly design has a vacuum hose that connects the cyclone to the drum and should help keep the bag inside the drum.  However, upon restart I have noticed that the bag wants to come out of the drum, and I can see it in the clear 9" flex tube between the bottom of the cyclone, and the drum--at which time I immediately shut off the machine.  I have checked the vacuum line between the cyclone and the drum, and the line is clear.  I have also checked the vacuum port at the bottom of the drum, as well as the tube that goes into the cyclone, and both are clear.  So, my understanding is that the vacuum tube is supposed to prevent a pressure difference across the bag, but it doesn't appear to be working.  Can you provide any support or direction to how I might resolve, as Im afraid to just let it run and see what happens when I start collecting sawdust.
For an additional piece of information, I have not changed the external air filter on the cyclone exchaust since I purchased the machine.  I have used the cleaning brush several times, but have not changed the filter.  Could the additional pressure differential caused by a dirty filter cause this issue?
I greatly appreciate your help/advice,
Raymond
Great idea to check if there is suction.  I took the bag out, and disconnected the hose at the drum.  I turned on the cyclone, and indeed it does have suction.
I have replaced the bag a couple times to make sure it's not the bag.  I have also tried "sealing" the bag a couple different ways to the drum, once over the lid gasket, and once under the lid gasket--no difference in the outcome.
Posted (edited)
I have the same machine and bought mine about the same time as yours. I have no idea why your cyclone has suddenly started sucking the back upwards. I've always had to use the metal liner that fits inside the bag and then goes into the collection drum. This keeps my bags from being sucked up. I can't remember what the metal liner is called and I didn't find it after a quick search on the grizzly site. A very quick search. You might have better luck. You might also place a couple of bricks in the bottom of your bag until Monday and then call Grizzly's customer service. I'm sure they can help you out.
After a little more searching - I found what I was talking about on the Grizzly website. It's called a bag holder if you want to do your own search. I only found the 35 gallon size.
Edited by Keggers
  • 3 months later...
A quick update on this question...I finally figured out the problem, and it was actually simple.  I replaced the canister filter, and changed out the bag to the grizzly specified heavier bag, and still had the issue--the bag was being sucked up into the cyclone cone.
I was sitting on the ground looking at the vacuum breaker hose and checking for suction, when o realized that the collection drum itself likely had leaks. I had previously used this cyclone with only the "short" drum, and when I moved my shop I expanded it with the additional ring to allow larger capacity.  This required moving the three clasps from the smaller drum base, to the expansion ring--and this left two small holes where the clasps used to be.  I removed the bag, and taped the holes with hvac tape, and also taped the inner joint between the expansion ring and the smaller drum.  Put the bag back in, fire it up, and presto--a perfectly functioning cyclone.  It's a shame it took me so long to figure out, but thought I should share the solution....if you have this problem, and a working vacuum line: check that the drum itself is sealed.
Happy New Year!
raymond
  • Who's Online   3 Members, 0 Anonymous, 68 Guests (See full list)
    26,008
    Bob44
    Bob44
