Pre-finishing exterior door panels
I am starting to prefinish all the panels for two sets of douglas fir exterior carriage doors. I am using epifanes mv.  Should I finish the tongue of the panel  and inside groove on the rail/stile that it floats in, or leave those unfinished.  I am going to use moulding that goes around exterior of panel with some flexible caulk for sealing.  Just seeing if I finish all the panels first then cut tongue around the edge or other way around.  Thanks!
Curt
I usually put one coat on everything just to seal the fibers.  Probably not necessary but it makes me feel better.  No need to go through the entire finishing process on those parts...
Thanks Eric. !   Also, would you do the same number of coats on the interior sides as you do exterior sides of the doors?
Probably.  The interior obviously won't have to endure nearly as much abuse, but anytime I can keep things equal on both sides of a board, I'll do it.  If you felt like putting one more coat on the exterior than you did on the interior, probably not a big deal.
Of course an exterior door is kind of different animal since it's constantly out of equilibrium anyway...a difference in the number of coats on one side vs. the other is the least of its problems.  But I always live by the "stacking the cards in your favor" philosophy.
