rasmussenjackr Posted March 11, 2011 Report Posted March 11, 2011 I am doing some upgrade work on my 1970s Craftsman table saw. The gentlemen that I purchased it from had added a dust collector kit that attaches to the motor and has hoses going to the blade guard as well as into the base of the saw. Runs great, cast iron top with cast iron extensions on both sides, little rust that I cleaned up, and at $100, a complete steal. I am waiting for a Delta T2 replacement fence to arrive by UPS - the factory fence is absolute junk. I have read the work it takes to get this fence installed, but have read great reviews. Now to my issue, I am removing the saw from the factory steel 4-legged base. One of the legs is bent, and since my shop is in my garage, I need to be able to move the saw. Sliding a cast iron saw around on a base with a bent leg is not easy or good for the saw. So, I am boing to build a wooden base with locking casters to set the saw on with an extension piece fitting between the T2 rip fence guide rails. I have seen many different styles on line, but they all have one thing in common - drawers on the front. I have concerns with the possibility of the drawers opening while the saw is in operation, and I do not like the idea of anything sticking out in front of me while using a saw that can easily send projectiles out if not paying attention. Does anyone have any experience with this? Has anyone built one? I am thinking of constructing two wall cabinets to put on each side of a base with a top spanning the two. This way, the cabinets doors open on the sides, rather than the front, eliminating risks of having a tripping hazard in front of the saw. Anyone have any feedback or ideas? Quote
jimmykx250 Posted March 11, 2011 Report Posted March 11, 2011 Sounds like a good idea. I personally built my stand out of angle iron and mounted the angle iron to a square wood base made of 2x4 lumber and i do wish i could use some of the wasted space below somehow. I dont see a problem with what you want to do as long as its rigid enough to resist and racking forces from bieng pushed around. Do you have any sketches? I will post a pick of what i did later today- this is inspiring me to look at my set up and possibly modify it. It's alot of wasted space below. I think you have a great idea pursue it. Quote
BuilderBill Posted March 12, 2011 Report Posted March 12, 2011 Here are a couple shots of the one I'm finishing up for my Bosch: Since these were made I've added the left-side extension table and the drawers. Just have to install drawer fronts and I'm done. Never had any concerns about drawers coming open, I us the K-V full extension slides and they have retainers built in. It's not like I'm going to be laying this thing over on an angle, anyway... HTH, Bill Quote
Alan Bienlein Posted March 12, 2011 Report Posted March 12, 2011 Here is my version of a mobile tablesaw base I'm building for my shop. I have the router table portion complete, the dust collection is complete and I just need to finish working out how I want to do the drawers. Quote
cmbp Posted March 15, 2011 Report Posted March 15, 2011 To keep the drawers closed, you could always try a simple latch. On my sailboat, the drawer rails have small bumps and the runners have notches - so you have to lift the drawer up a fraction of an inch to clear the bump before pulling it out. That might work, too, and there's no obstacles to catch yourself on. I'd be more concerned about access to the power switch. Have you considered moving it or putting a kill switch into a power feed line built into the cabinet? Quote
Texfire Posted March 16, 2011 Report Posted March 16, 2011 Here are a couple shots of the one I'm finishing up for my Bosch: Since these were made I've added the left-side extension table and the drawers. Just have to install drawer fronts and I'm done. Never had any concerns about drawers coming open, I us the K-V full extension slides and they have retainers built in. It's not like I'm going to be laying this thing over on an angle, anyway... HTH, Bill I'm planning on making something similar for my Bosch, but not quite as large, and with the stock fence. Thanks for sharing yours. Quote
BuilderBill Posted March 17, 2011 Report Posted March 17, 2011 I'm planning on making something similar for my Bosch, but not quite as large, and with the stock fence. Thanks for sharing yours. Tex, I have it drawn in AutoCAD, let me know if you want and I'll send you some .pdfs to get you started. I really didn't need it to be so large, but the Incra fence comes with 6' rails and it was either utilize the space or drag out the Sawzall... I'd really recommend an aftermarket fence but it's hard to do with the saw alone. I had bought the Rousseau setup along with the saw and just took off the legs to use it to bolt the Incra onto. It was a case of using what I had. I gave some serious thought to building around the Jet ProShop saw but that would have cost me another grand out of pocket and I'd have been really lucky to get half what I'd paid for the Bosch/Rousseau combo on Craigslist. Borrowing from David Charlesworth, I'd have to say "I'm well pleased" with how it turned out: And I'm particularly "well pleased" with finally having a drawer just for router bits although it's already a bit crowded and I can see the need for expansion: I really enjoyed building this, not so much because of any technical challenge but because it was a chance to really evaluate my workflow and storage requirements, then translate that into a piece of cabinetry. And it was an opportunity to remember just why I've always hated laminate work... Have fun, spend at least as much time thinking as you do building, you'll come out with something you can use for a long time! Best, Bill Quote
Texfire Posted March 18, 2011 Report Posted March 18, 2011 Absolutely, I'd love some PDFs so I can see the dimensions and internal construction, thank you. joquinmail(at)earthlink(dot)net I've considered going the Rousseau route as well, was planning on doing that and constructing a rolling base at first. But if I got the frame, outfeed and router extension I'm looking at almost doubling the price spent on my saw. I think I'd be better off putting that money towards purchasing a real cabinet saw if I went that route. My intended use for my tablesaw has changed as I have read threads in this forum. I at first wanted to modify my benchtop saw to gain full sheet capability, but I'm now planning on using a jig saw, circular saw with straight edge, or a track saw for reducing sheet goods then using the table saw for final dimensioning. Seems to be safer and more accurate than wrestling around full sheets like I was planning. This allows me to still use the tablesaw for dados, and crosscuts with my miter sled. Current thinking, I'm planning on building something more like you built, a rolling cabinet that has storage space underneath, and the dust output plumbed internally to a 4" external dust port for connection into my DC system. I am going back and forth on building it larger so I have permanent outfeed with the tablesaw sitting on a recessed platform to level the table, or making the cabinet the size of the saw with the tab extension extended and adding folding outfeed and left extensions for handing bulkier goods. I'd love a sliding table, but see the above comments about doubling the cost of the saw with addons. The really crazy idea I have is this. Extending the table and putting a router insert in the hole that's formed by that. Any thoughts on the viability of this? The hole is 21-7/8" x 11.5" square. Quote
Texfire Posted March 21, 2011 Report Posted March 21, 2011 I think I'm going to chuck the router table in the hole concept. It's just barely big enough for the insert, which would make t-track for the fence difficult to squeeze in. Add in the irregular space below the hole and making a mount to hold up the insert would be problematic. I would need to get an aftermarket fence so I could fit in a full sized router table by the saw. Instead I'm thinking of mounting my Jet 10" jointer/planer and the Bosch 4100 side by side on a cabinet. The rear of the cabinet would go up to the table surface height to hold the dust plumbing from the saw, and to allow me to add a 24" folding outfeed leaf across the rear of the cabinet. Both the jointer/planer and the table saw could be plugged into a power strip that has an extension cord I could run to a wall outlet, as well as a common 4" dust port for my DC system. I thought of making the outfeed a full sized router table with mount in the center, t-tracks and a removable fence, but think a stand-alone unit in the future would more effective, and the 30" width with the outfeed folded up is easier to shift in the shop if I have to park the Jeep inside. Quote
dgem1st Posted April 30, 2014 Report Posted April 30, 2014 Here are a couple shots of the one I'm finishing up for my Bosch:saw cabinet-2.jpgsaw cabinet-3.jpg Since these were made I've added the left-side extension table and the drawers. Just have to install drawer fronts and I'm done. Never had any concerns about drawers coming open, I us the K-V full extension slides and they have retainers built in. It's not like I'm going to be laying this thing over on an angle, anyway... HTH, Bill Hi Bill, Great job on the table saw cabinet! I have a bosch 4100 and a incra router table. was planning a cabinet to fit them all together so i can get the TS-Ls rails to work with them both. Just wondering if you would mind sending me some pdf's of your autoCad design. the router table is wider than the 4100 so ill have figure out a way to add some tabletop area to the 4100 to make it all work. Also any advice on the incra rail installation would be super appreciated. Thanks so much, Darin Quote
BuilderBill Posted May 1, 2014 Report Posted May 1, 2014 Hi Bill, Great job on the table saw cabinet! I have a bosch 4100 and a incra router table. was planning a cabinet to fit them all together so i can get the TS-Ls rails to work with them both. Just wondering if you would mind sending me some pdf's of your autoCad design. the router table is wider than the 4100 so ill have figure out a way to add some tabletop area to the 4100 to make it all work. Also any advice on the incra rail installation would be super appreciated. Thanks so much, Darin Darin, Files attached, look them over and shoot me a PM if you have questions. Like I said, this was designed to mount the Bosch with the Rousseau frame but I wouldn't buy the Rousseau just for that. I'd just make the left end panel as tall as the right side and put a short return on the front and back of it, maybe 2-3". Then you can bolt the Incra mounting brackets for the rails to the cabinet sides on the right and the returns on the left. One more thing: the height of the right side was based on removing the lower black thingie on the bottom of the Bosch and the way it set in the Rousseau frame. You may want to make some adjustments depending on how you want to mount your saw. I'd suggest picking up the Incra kit first so you have a reference for the adjustment range in the brackets. Good luck with your build! Bill P.S. I mounted 3 pairs of casters, left, right and between the saw and router sections. I also pocket-screwed and glued a recessed skirt with a gridwork inside to the bottom. This thing can get heavy when it's loaded and you don't want it sagging.table saw_router table cabinet revised.pdftable saw_router table cabinet drawer layout.pdf Quote
