Lucky1406 Posted January 5, 2012 Report Posted January 5, 2012 I have a Harbor freight dust collector and was wondering if I were to install a larger motor that turned faster, would that increase the CFM and make it more powerful? Would the Harbor freight 2HP Dust collector be able to accept a 3HP Motor? (Please not harbor freight bashing, I know they have bad tools, but this Dust collector has had great reviews all across the internet. And It's less than half the cost of similar units. Every once in a while, they have good stuff. I'm just trying to search for more power.) Would it be able to handle the faster speed? Thanks, Nick Quote
Beechwood Chip Posted January 5, 2012 Report Posted January 5, 2012 I don't know the answer, but I bet Bill Pentz does. Quote
PaulMarcel Posted January 5, 2012 Report Posted January 5, 2012 The 2hp and the 3hp motors will turn the same speed. I have that DC and it works well even though I'm using all the wrong hose to the tools (4"... flex... bad turns...) yet it still performs well. If the 2hp doesn't seem to be keeping up, what is the problem with it? There might be a simpler solution than a larger motor. Quote
Jfitz Posted January 5, 2012 Report Posted January 5, 2012 Nick - from what I've read, the limiting factor is not necessarily the motor, it's usually the impeller. Even if you could get the impeller to spin faster, there will be other issues that simply prevent it from drawing more air. As mentioned above, a higher HP motor will not necessarily lead to spinning the impeller faster. A more viable upgrade would be to replace the bag (or whatever you have on it) with a better quality item, such as a Wynn cannister. It seems that many people have had great success with this type of upgrade. Also look at ways of streamlining your duct or hose layout. Quote
