doghole template printout problem
I have printed out this template 4 times with no resizing only to have it be a little under scale. Is this normal and is anyone else having this problem. Even when I download the pdf plan v9 and hold my ruler to the computer screen I get the same thing. Top is at 3 7/8" light, 1" squares are at 31/32" and so on. HELP!!!
Some printers are more accurate than others, so you are probably doing everything correctly. You might just have to take it to a copier and scale it up or down there to get the dimensions correct. You could probably also do some heroic calculations and create a custom paper size and enable fit to page scaling to trick your printer into printing to scale, but that would be an epic battle!
Also, there isn't anything really sacred in the dimensions of the dog holes. You could just use the template as is and adjust the dogs a little.
kaiser,
Are you using a laser printer or an inkjet? I have heard that inkjet printers are better at printing things accurately and at an exact size than laser printers. (I've also seen this myself, although only with one example of each type, so I'm reluctant to generalize.) Could be at least part of your problem if you're using a laser printer.
-- Russ
kaiser,
-- Russ
Yes on the laser printer. I have already made a template out of 1/4" plywood and just drew it myself...Thanks for the help guys.
Thank you Aaron. I just drew my own based on dimesions given. I also had a problem with the tail vise template, because there is no dimesion ffor the center of the screw hole horizontally, but got that one worked out too. You and Marc are doing an awesome job, keep it up !!!!
KAISER OUT
Yeah, the tail vise template is from Benchcrafted directly,so not much we can do about that one. Sorry, but glad you got it worked out. I think Marc should cover all the details in his future videos.
I think that Jameel just posted a new set of tail vise instructions with a template to correct his problem.
