I just purchased a Grizzly 14" bandsaw (G0555P) and starting to learn what I can do with it. I think I want to pick up a riser kit but I'm really struggling to understand how it works. Can someone explain to me what is done during installation and/or what I get by doing so.
What I think I get is the ability to resaw a 12" board, up from a 6" board. Can anyone confirm (or not)? Any pictures of a saw that has been upgraded?
Thanks!
-K
I have the Grizzly G0555, which I think is basically the same as yours except not the Polar Bear series. I recently purchased the riser block kit, but haven't installed it quite yet. You're correct that it will increase the resaw capacity from 6" to 12". Basically there's a metal piece that increases the distance of the upper portion of the saw from the saw table. It also comes with a longer blade, which is required since the distance around the wheels is increased with the riser block.
There are a few pictures of the installation available on Amazon (link below). The pictures show a Delta saw with the Grizzly riser kit. The kit from Grizzly actually works with several brands of 14" bandsaws from what I understand. I can't personally comment on how well it works since I've yet to install mine, however, the kit gets pretty good reviews from what I've read. There may be some other folks that have installed and used it that can provide more info if necessary. Hope that helps.
http://www.amazon.com/Grizzly-H3051-Riser-Block-G0555/dp/B0000DD4HM/ref=sr_1_1?ie=UTF8&qid=1326253042&sr=8-1
I purchased everything together from amazon. Saw, Riser, and Rolling base. And I just installed the riser kit on my G0555. The kit comes with everything needed to extend the capacity to 12" and the installation and changeover was a piece of cake. You will need a couple large wrenches and sockets to change the bolt that holds the neck and block to the larger size. It is also helpful to have an extra set of hands and have someone hold the top assembly up for you while installing and bolting in the riser. Otherwise putting on the longer blade guards and safety guide is simple. Just follow the directions step by step and you should have no problems. (read the manual? what?) (helpful though) The block looks great and matches perfectly like it has always been there.
I also made a few upgrades while i was at it. I ordered the mounts for cool blocks from Grizzly and installed them while everything was apart. I also bought a woodslicer blade from Highland woodworking and set aside the one in the Grizzly Kit as a spare. You can check out a review of the wood slicer blades here. Sharp!!
Extremely happy with the G0555 and riser kit. With the new blade and capacity this saw is a beast!
Thanks Rusty Bob 8 for the additional information and especially the link to resaw upgrades. I'll watch that review and read about the blade some more. Right now it's a toss up between the Wood Slicer blades and Timber Wolf blades.
  • 3 weeks later...
I picked up the the riser kit but haven't installed it yet. I also snagged a 1/2" 3 TPI Timberwolf blade from a local Woodcraft. Excited to see how well this thing resaws. I might even go with a 3/4" 3 TPI in the future to see if it performs any better.
Hey Rusty Bob 8, do you know what the part number was/is for the G0555 and/or G0555P?
  • Who's Online   2 Members, 0 Anonymous, 50 Guests (See full list)
