tdale51@yahoo.com Posted March 9, 2012 Report Posted March 9, 2012 I was looking for opinions on honing a secondary bevel on the blade of a LN low angle rabet block plane. The blade is bedded at 12 degrees and factory sharpened at 25 degrees for an overall angle of 37 degrees. If I were to put a secondary bevel on this blade the effective angle would be closer to 40 degrees. Will that negate any benifits of a "low angle" plane? Quote
JohnnyNoName Posted March 9, 2012 Report Posted March 9, 2012 The benefit of a low-anlge, or bevel-up, plane is that you can create almost any cutting angle that you want. I would try putting the secondary bevel on and see if it cuts well for you. If it doesn't, regrind the primary bevel to something steeper/shallower and try again. Jonathan ====================================== Quote
ChrisG Posted March 9, 2012 Report Posted March 9, 2012 The choice to use or not use a secondary bevel is, to me, more about preferences in sharpening techniques. I wouldn't worry about a couple of extra degrees. I don't think you'll notice any difference between 40 and 37. Plus the slightly steeper angle on the blade will improve the strength of your cutting edge. 40 is still a pretty low angle, and even higher angles will cut end grain just fine if you keep your blades sharp. Quote
