MarcoG Posted June 27, 2012 Report Posted June 27, 2012 I know there is a thread (well, there's probably a dozen...) about which planes to buy. But I'd like to have something clarified that I think does not quite fit in that topic. As I've learned, it's better to use a plane at an angle to get better results. This, I've been explained, is because that way, the blade will work at a lower angle relative to the wood. So, says my mind, aren't there planes with low angle blades available? So my question is this: If the lower angle is advantageous, what is their disadvantage? I mean, the 'normal' angle planes are still sold so there must be a use for them as well. Quote
rmac Posted June 27, 2012 Report Posted June 27, 2012 Lower angle = good for end grain. Lower angle = easier to push in well behaved wood. Higher angle = harder to push Higher angle = less tearout in wood with interlocked or swirly grain. -- Russ Quote
Onboard Posted June 27, 2012 Report Posted June 27, 2012 Here’s a short article that goes along with what Russ has already posted. Quote
