Advice on Outdoor Finishes
The original design was for a friend’s cabin.
post-6734-0-53541100-1341078027_thumb.jp
This one was made from Alder and finished with General Finishes Outdoor Oil.
I need some advice on the best way to make the background POP ?
post-6734-0-40065900-1341078128_thumb.jp
Maybe a water based gel stain or a paint. Oil based might be good too because it will stay wet longer. Whatever you choose it will have to be able to dry on the surface. Put it on and wipe it off and leave it behind in all the groove and detail areas of the carving. Maybe spray (so your brush dosent pick up any color) a topcoat over it once it dries good. Practice on something else first.
Good luck
Best way to pull out the grains for eye catching effect in my opinion is to sand down lightly and build coats using poly/ real tung oil and some mineral spirits. Third of each or whatever you choose, just dont overdo the mineral spirits.
Sometimes i dip a recently used stained sirring stick in there and it gives it a little color. But thats an unorthodox , i.e. cheap, way to just add pigment.
Thank you taking the time to comment.
I will make up some sample pieces and give your ideas a try.
Thanks again
  • 26,009 Total Members
  • Joseph b Newest Member ·
