adambaum Posted July 10, 2012 Report Posted July 10, 2012 I'm having a problem with a PC pin nailer. I managed to get about 50 pins or so through it before I encountered my problem. At first, I thought it was jammed so I looked in the manual for fixing jams. I followed the instructions and removed what appeared to be a jammed nail. However, I don't think jamming was the problem as the pin nailer won't shoot any nails. I can remove the nails from the gun no problem. All load and unload easily. I can hear the gun shoot air when I pull the triggers (safety and trigger), but nothing shoots out except air. Ideas? Adam Quote
jimmykx250 Posted July 11, 2012 Report Posted July 11, 2012 Sounds like the piston that drives the nails could be broke. It's not a difficult part to replace but if it's new that warranty should replace it. I replaced one on a pc finish nailer and the part was 50 bucks and tock 1/2 hour to complete. Check your owners manual or go online to find a parts breakdown. Wish u luck. Quote
TimV Posted July 11, 2012 Report Posted July 11, 2012 Or, are the nails not getting pushed into the "firing chamber"? I've had this happen with my framer and I needed to lubricate the way and spring. Quote
adambaum Posted July 11, 2012 Author Report Posted July 11, 2012 I think the nails are making it into the chamber. When I load the nails, a guard at the front gets pushed forward a bit. If I look down (no air attached) the nose, I can see some shininess, which I am assuming is the nail. I'm going to take it to a repair center...the part that really sucks is the nearest one is over 30 miles away. Adam Quote
