Linseed Oil and glueing
Hi All,
I have been making a jewellry box for my wife and have run into what could be a problem.
I finished certain portions of the box with boiled linseed oil while they were unassembled and I was careful not to apply the finish to the areas that needed to be glued. It appears, howerver, that the oil has soaked through and saturated the wood throughout, even the parts that I taped off.
Will I have to switch glues from the PVA glue I have been using to an epoxy or should I shellac and then finish the glue up?
Any advice on how to correctly proceed would be appreciated.
Chris
I think if it was me I would scuff up the areas that I was concerned about with some sand paper just to give the areas some tooth. Than glue the box up with PVA I think the glue will hold just fine, with epoxy you would have the same problem and have to sand the areas also, squeeze out would be alot harder to deal with than the PVA.
P.S. I geuss I was thinking the BLO was cured if so my advice stands, if not wait for the BLO to cure before proceeding.
  • 26,009 Total Members
  • Joseph b Newest Member ·
