rubus Posted August 31, 2012 Report Posted August 31, 2012 The rubber sleeve which goes over the lower wheel keeps slididng off when i run the saw. Any suggestions as to why this is happening? Thanks in advance. Shane Quote
minorhero Posted September 1, 2012 Report Posted September 1, 2012 I assume you mean the tire. If it is black then it is because the glue that was holding it on has given way. If it is blue or orange it is because it has stretched out too much and needs to be replaced. Either way you will need a new tire. If this is a very very old bandsaw (early 40's or earlier) the wheels will not have a lip on the edge and you will need to glue the tires regardless of what type of you buy. If it is newer then that then the wheels will have a lip on the edge that will hold a new tire in place. My suggestion is to buy some urethane tires (sold by various online and brick and mortar retailers) and then install them. There are a number of online tutorials and videos that will show you how to do this. Good luck. Quote
