Transfast Dye issue please help.
I started a guitar project and mixed some transfast with water to stain the fame maple top. I tried with a rag and worked horably. I then took a paint brush and painted on the black finish heavy. It took a while to dry but when i thought it was dried i left and the color was pitch black. Two days later it looked like this. I dont know what happened i wouldent think it would have soaked in this much. The white color comes off but it appears to be brownish still. Would another coat work at this point or is there something else i should do. I want to enfasize the grain and sand back so that i can use a transtint product of another color. Any help? Thanks.
post-7997-0-27011900-1353946103_thumb.jp
post-7997-0-37187600-1353946109_thumb.jp
post-7997-0-54736100-1353946114_thumb.jp
What were you trying for?
The 'tiger stripes' will absorb more dye then the surrounding wood. Charles Neil has a very good video (think it's on his free site) on bringing-out the stripes in tiger. Basically, you flood it and let it dry, then lightly sand-back leaving the dye in the stripes. Then coat in 1.5lb cut SB as a seal coat, then lacquer.
The thing to keep in mind is that wood is absorbant. The more you flood on a finish, in many cases, the deeper the finish will penetrate. So by the time you applied a second coat of dye with a brush, you should probably expect a very dark (and ugly) presentation. Keep in mind that all dyes look ugly once dry. So don't take that comment personally. :) As soon as finish is applied, they really jump back to life.
Now I see some weirdness in the pictures you uploaded. Do you have any idea what those triangular shapes are? Is this an area where you started sanding? If so, I'm afraid that the surface might not have been adequately prepared for the dye. Can you briefly describe what you did prior to adding the dye (in terms of surface prep)?
Without more info, here's what I would recommend. First, you might try wiping the surface down with a clean/damp rag. That might help lighten the amount of dye on the surface while driving it a little deeper into the striped/thirsty pockets. Once dry, start sanding. Even in a best case scenario, this is part of the process. The key is to sand back just enough to lighten the primary background while leaving the dye in the absorbant "stripes" of the wood. This gives you the intense contrast you're looking for. Just keep in mind that when you use black, you will almost always retain some color in the lighter wood. As you sand, lightly wipe down the surface with a damp rag to get an idea of where you're at. It will likely take more sanding than you might initially expect. Hopefully, you'll eventually arrive at a point where the background is mostly "clean" and the stripes are nice and dark.
I have a video on the topic here: http://www.thewoodwh...goes-the-maple/
Just keep in mind I decided to use some shellac in my dye mixture and that's definitely not a required step. Dye alone will work just fine.
For prep I sanded with 220 then applieddye after cleaning the surface with a dry cotton cloth. I tried a piece of pine board and from the videos I have seen the dye soaked in fast as it did with the pine sample. However, when applied to the maple guitar top it took a long time Luke 30 minutes. I did two coats so one hour total. Should I have mixed the dye with alcohol aposed to water in increase dry time and to prevent the dye from soaking in too much? And if I put another coat on will it begin to stay on top of the wood instead of soaking in do much?
The alcohol would certainly make the dye dry faster, but I'm not sure that's going to help the situation. Do the weird markings go away as you sand the surface?? Just curious. I'm wondering if this guitar was previously finished?
Either way, absorption doesn't seem to be your problem and at this point I don't think there is any benefit to adding more dye. Seems to be plenty of color on the surface. Your goal now is to remove some of that color.
The whitish markings do whips off with a dry cloth I will have to get updated photos but the color seemed to be more brown than black.
  • 26,009 Total Members
  • Joseph b Newest Member ·
