Wall hanging cabinet, tool rack or both? Or maybe something else...
I need somewhere to store my handtools for my new shop and need some ideas of what I could use.
I have Chris Schwarz book on workbenches and in that saw his idea for an over the bench tool rack that comprises a couple of 3/4" x 4" base mouldings glued together with four 1/2" thick blocks and then screwed straight to the wall covering the window. In that he put a high density of tool, chisels, screwdrivers, saws etc and then added a few extra shelves for hammers, mallets and other tools.
I thought that would be a superb use of space over my bench.
However I also have an extensive collection of wood planes of many different types. I think I need some sort of storage for them, maybe a wall hanging cabinet similar to Marc's cabinet in the WW Guild. This could hold the planes vertically for the regular type of bench plane but the router planes, rabbeting planes and other specialty planes could do with cubbies or pigeon holes.
I think the criteria are:
  • Tools must be easy to get to and within arms length
  • Tools must be protected from moisture, dust, hitting adjacent tools etc
  • Doors could be used to enclose any cabinetry
  • Enough space for (inevitable) expansion
A floor chest (like the anarchist tool chest) is not a good idea in my relatively small shop.
I'm interested in finding out how you store your handtools.
Any other ideas people?
I have a wall hanger in my shop/garage. It is always open and it houses 6 hand planes and a bunch of hand tools, chisels and so on. It's built from b2 birch plywood and a piano hinge. I didnt spend alot of time or money on it because it's a user not eye candy or something im afraid to scratch. The tool box by schwartz isnt practical for the average home shop guy unless you like to be bent over all the time. If you are like me you wont regret building it because you will use it every time you are in the shop!
Vote wall-hanging... I think I'm on my forth generation... Having the tools at eye-hand level is important to me....
I have a separate hanging saw till, separate plane till, separate hanging chisel rack and hanging cabinet for 'everything else'. I did this because I wasn't sure how my plane, saw and chisel needs would grow over time, so I didn't want an 'end-all-be-all' hanging cabinet. This turned-out to be a huge amount of fore-site -- within two years, I discovered Japaneese saws and purchased a couple, so need a new saw till. Same for planes (router planes, molding planes, etc). It's very easy to knock-out a saw till (maybe a day) or a plane till (maybe two/three days), but the 'end-all-be-all' cabinet is quite an effort. The only drawback in having 'specialty' tills is the increased wall space required.
I'm going to build a new 'everything else' cabinet using plans based on FWW's latest cabinet (Pekovich) crossed with their last cabinet article (Becksvoort). I'll move the chisels into the that cabinet to free-up some wall space.
I have a closet for a shop. Because I need to maximize storage for minimal space, I've been looking at the hanging rack... with a minor modification. The concept I've been looking at is Marc's hanging cabinet, but I'd add an extra set so I could add a second set of doors on the inside. (outside opens up to show another set of doors that open the other direction.) Plus, since I can't drill into the walls to mount this, I've been looking at a construction grade frame to hang it from, allowing for construction of a second cabinet.
I purchased the small shop storage magazine from Wood a couple weeks ago, and there's an example of a rolling tall cabinet that I think I'm going to consider. The article is the one where the guy built a light stand on a heavy base, but his shop is a two car garage (that gets used as a garage). (Come to think of it.... most of the shops in that magazine also had hanging cabinet style tool storage...)
I like wall cabinets, drawers under everything but my main bench, and rollaways. I don't like open storage, for dust and rust reasons. I use renewable silica gel packs in all cabinets and drawer boxes. All machines have their accessories, sundries, and frequently used tools collocated. Sometimes, it's well worth it to spend a few bucks on extra wrenches, hex keys, etc, extra ear muffs and safety glasses, or some extra cans of wax or Top Cote to leave at each machine... that are frequently used and can live right there with a tool.
The "main" bench wall cabinet gets ONLY what you need within arms length for layout, fitting, and other bench work. Planes, layout stuff, chisels, rasps, scrapers, screwdrivers, saws, a wax block, very common screwdrivers... And of course, a few band aids. In my case, this cabinet is behind me.
I don't like drawers in the main bench, because I like to put a hand tool back in it's home between uses, even if I'll be using it again in five minutes,and there often seems to be something blocking access to the drawer I need right now.. For example, when I've completed an operation with my smoother, I place it in it's slot... At the end of the session, there's no cleanup, and there's no setup at the start. Hang the chisels and squares, pick up the few tools sitting on the bench top, close the doors, and come back tomorrow.
Router bits and bases, sanders, carving tools, drill bits, pocket hole jigs, plate joiners, etc... can come out as they're needed, and don't usually need to be instantly available.
Basic sharpening gear needs to be out, too... Sharpening touch ups should be a constant process, not something you do on a special day.
When thinking of storage, think hot, warm, and cold. Hot at the bench is things like bench planes, chisels, squares, pencils and knives, bench hooks, holdfasts, a few clamps you use all the time, or your 4000/8000 grit stones, guides and setup jig. This is stuff you need quick and frequent access to, ideally being able to put it down in it's home at the end of each touch. At the table saw, hot might mean adjusting wrenches, blades, sleds, and inserts. Warm is things like router bits and bases, carving or inlay tools, your spokeshaves, adhesives, and things like brad guns. Cold storage is for things like spray rigs, spare jointer and planer knives, extra materials like unopened rolls of tape or bottles of glue, extra a/c cords or air hoses, hardware, or finishes. Things where it's OK to move a few other things out of the way or walk to another room to get to, as you're doing a specific, not so often operation.
Always remember that cleanup and setup time is non-productive time... Minimize it.
hot/warm/cold...... hadn't thought of that concept...
(Of course, I'm staring at a snow drift in the center of the work area right now, so I'm probably thinking something different... But I'm going to keep this in mind for the next few months until I can get back into the shop. Thanks.)
