I am posting this on behalf of a Russinan Guild member that doesn't speak English. He's hoping to import a Powermatic saw and is trying to make sure the motor will run. I'm hoping someone in the forum has experience with the conversions that might be necessary. See below.
Motor specification:
HP: 5
Phase: 3
Motor Voltage: 230,460
Prewired Voltage: 230
But I can’t get answer from Powermatic about difference in voltage.
This motor adopted to USA 3 phase 460 volt 60 Hertz
But in Russia I have 380 volt 3 phase 50 Hertz. (220 volt between ground and any phase)
Difference in Hertz I plan to solve using frequency inverter:
http://www.ebay.com/...984.m1436.l2649
But I’m also have difference in Voltage.
Is motor will run in Russia or not?
Some (actually quite a few) motors can operate at both 60 and 50HZ --- 60HZ at 230/460 and 50HZ at 190/380 because v/Hz is the same. You need to look at the motor’s plate, not what is in Powermatic’s owner’s manual. Assuming the motor can operate at 50hz, there will be RPM and HP loss. It also depends on the service factor (also on the plate) – the lower RPM impacts cooling and service life. A SF of 1.0 will overheat on the lower RPM. Something from 1.15 or 1.25 should be fine.
If the motor is not designed for both frequencies, you will lose RPM, HP, torque and v/Hz will be out of design spec -- i.e., the motor would probably self-destruct over time. While some folks are fine with VFDs, I would spend the $$ on a new motor…
I just took a look at one of my newer PM’s 5HP motor tags – unfortunately, these newer PM tools do not use Baldor, Leeson, et al... I forget the attribution, but the phrase, “motors with names that I can’t pronounce” comes to mind…
PM affixes their trade dress plate which conveys a bare minimum of information – well below the IEC standard…
I notice that it’s a Class A (105c) motor. If the tool he wishes to import is also class A, then I would not run it on 50Hz.
  • Who's Online   1 Member, 0 Anonymous, 44 Guests (See full list)
