Started to draw up my shop
I finally got the wiring done. I made sure to cross my T's and dot my I's when it came to that. I have three outlets in the ceiling, all three are powered by a toggle switch as I enter the room. The outlets have three 2 bulb lamps connected to them, and then I have one open slot each outlet, in case I need to plug something in above me. Worked out pretty well. I have to adjust the height of them a little bit to max out my head room. I don't hit them if I walk past them now, but the higher the better.
I am pretty confident when it comes to my ability to follow directions, and that is why I felt like I could tackle this project on my own. I read numerous books, websites, articles, and found a general consensus on how the wiring should be done. I weened out the outlying information, and settled on a diagram that was exactly what I wanted.
Next, I want to wire 4-5 more 120v outlets on a new circuit, and place them all along my wall. Also, I need two 240v outlets as well, on the same wall. Now, I have a question about how I should mount them. The wall I am going to go off of is an outside cinder block wall. I am in the basement, and to my surprise and joy, the water problem is almost non existent. However, I do not want to mount straight to the wall, if for some reason a stream of water decides to make it's way to my outlet(s). What is a good way to go about this?
wish i had joined this thread earlier :)
happy you've made some progress! We recently re-did our shop and i got the chance to design my dream wiring scenario. I worked with an old wiring specialist for 3 years and learned a thing or two about electrons :P
after completely gutting our detached 2 car garage with concrete block walls, i was so giddy to get wiring.
the subpanel idea is a good one for several reasons. you only have to get your hands in your parents electrical panel once. then you have your own little woodshop service which you can add/modify and play with for as many times as you'd like. god forbid you blow the whole subpanel breaker , you run less risk effecting the main panel which could effect computers, appliances and etc in the rest of the house.
i put all of the lighting on it's own 15A breaker. you don't want a tool blowing your lights if you can help it.
i staggered my outlets on the wall. in this photo, http://www.flickr.com/photos/skjinnyc/8030699403/in/photostream ,
you can see the plugs connected with 1/2" EMT. what you can't see is that every other outlet box (two duplex receptacles per box) is on it's own 20A circuit. I made sure not to over flow the conduit using the NEC wire fill table for EMT * i think 9,  12 gauge conductors is the max for 1/2"...  i can double check that if you need. (i have the 2010 NEC handbook).
you might want to think about staggering your plugs. even just to two circuit breakers. if you have a skilsaw in one plug, and the vacuum in the other plug closest and they are both on the same circuit, you run a greater chance of popping the breaker. by staggering the plugs, you allow yourself more play time and less stoppage time. The way i was taught to interpret the code was that the more plugs around, the less chance for electrical problems. (this is where i could go way deep into load calculations and code references) but i wont... lol
to help answer your question: my suggestion would be EMT and metal 4square boxes. to attach the boxes to the concrete, i use the klein yellow anchor kit from home depot with my corded non-hammer drill. comes with the right sized diamond/carbide bit and everything you need. if you feel like you need additional "protection" you could use the metal or pvc weather proof boxes but it gets expensive quickly. i only use that stuff for outdoor projects. if a stream of water makes its way to your outlets, based on the images you supplied, your circuit breaker will most likely trip before anyone or tools get hurt.
for your 220 situation,  if it were me, i would put both machines on same circuit only if the motors required the same breaker. i don't know if this code friendly or not but it's just a small home shop, use common sense. i just got a new(used) table saw with a 220 3hp motor. i looked at the amps section on the motor spec plate and it said 15.2 so i put it on a 2 pole 20A breaker. if i got a bandsaw, for example, and the motor said 21.3 amps, i would put the bandsaw on it's own 30 A breaker instead of changing the 20 A table saw breaker to a 30A and connecting the two. circuit breakers are awesome. they are kind of like 24/7 tool protection.
have fun!
  • 26,012 Total Members
  • JAR Newest Member ·
