baok Posted May 30, 2013 Report Posted May 30, 2013 I’ve read quite a bit (and watched videos) on the subject of how you stand and use your body when hand-planing. Conventional wisdom has you stand more or less behind the stock and push the plane. But I swear that I have more fun with it (and sweat less) by standing beside the stock and scooting the plane sideways. I suppose it doesn’t matter as long as the work gets smoother and/or straighter. Mind you, this doesn’t really work when I try to edge-joint long boards but no one technique is good for everything. Quote
Tom Crawford Posted May 31, 2013 Report Posted May 31, 2013 I tend to use the stand beside more than stand behind. I also occasionally use a 'Japanese' stand behind and pull. Quote
jhl.verona Posted May 31, 2013 Report Posted May 31, 2013 When I need very fine control of the plane and the piece is not too long, then I find that I get better results by locking my arms and using my legs. I try to do this when smoothing or jointing - take a look at David Charlesworth 'in action' to see what I mean. I stand just behind the board, weight on my back leg, then move my weight forward onto my front leg - I keep my legs about 80cm - 36" apart. I can do this on boards up to about 24" - 60cm. Anything longer, and I'll extend my arms at the end, because I only need forward pressure at the end of a cut. On less precise work (or at least because I get less precision) I'll use my arms more. Scrubbing, flattening, thicknessing. I always try to leave myself a bit under 1/2 mm (1/32") for final smoothing. Sometimes the board is just too wide or long for leg work, so I'm forced to extend my arms, but if I also have to outreach (because of the width) I much prefer to pull from the other side or swap hands rather than overstretch myself. I am not of gorilla build, so if I have to face an extended planing session, I give myself plenty of breaks - usually doing other things. There's nothing worse than tired arms or legs to ruin all that hard work, except maybe a dull blade. John Quote
G S Haydon Posted May 31, 2013 Report Posted May 31, 2013 Good recommendation John. David is a very methodical teacher from what I have seen. I caught up with some of his chiseling knowledge on YouTube, very detailed. Quote
