I am making some louvers with basswood for some shutters. I have cut the basswood to 7/16" thickness and either 25" or 12 1/2" lengths. Final lengths will be 12 5/16"; final thickness will be 3/8". I have a plantation shutter louver router bit from Rockler to shape the louvers. My question has to do with router speed with this soft wood. Do I speed up the router to get the best results or do I slow it down?
When in doubt, read the instructions.  Did the bit come with any documentation that specified a range of RPM?
Failing that, the general rule is thus:  Routers are built with variable speeds to accommodate different bit diameters.  Narrow bits can run at full speed, big wide slot cutters or panel raising bits must be run at a lower RPM.  With that in mind, looking at Rockler's site and assuming this is the bit in question:
...This looks like the former and I say run the router at high speed.  As to what cut quality this will produce, that depends on the stock you're working and how you feed it into the machine.
  • Who's Online   2 Members, 0 Anonymous, 49 Guests (See full list)
