No-wipe penetrating oil for exposed wood framing?
Hi All,
Thanks for considering this question from a newbie.
I'm refinishing the interior of a handsome 1902 building in Oakland California and want to leave its no-nonsense wood framing alone as much as possible. I'm working with a contractor who will lightly sandblast all the exposed wood surfaces: 12,000-15,000 square feet! Then we want to seal and perhaps darken the wood a little. I really don't want to paint.
I'm wondering whether there's an oil finish we can use that doesn't require wiping. (Wiping that much square footage of medium-rough-sawn wood, including exposed rafters, sounds like way too much effort--if it's even possible.) Perhaps a few lightly sprayed coats of a well-thinned boiled linseed or tung oil?
I used oil on a 1750s timber frame cabin in the Adirondacks and it looked beautiful; that's the glowing/touchable kind of surface I'm looking for. (I'd beeswax the whole thing if I could, but that's crazy man-years' worth of work...) Or maybe there's another approach entirely that will let the wood glow naturally and offer a little protection and darkening without huge amounts of effort?
I attach a stitched-together panoramic view of the second floor, in case you're interested; there's a ground floor & mezzanine, too. (Yes, that actually is a loading dock & winch 23' off the ground on the second floor...  ;)
Best Regards,
Brad
post-14602-0-96776500-1381091501_thumb.j
Great idea. Funny, when the contractor mentioned sandblasting I "invented" CO2-blasting, seemed like it might work and be easier cleanup--but he hadn't heard about it so I didn't try to find a resource. Thanks for making it real!
I'd CO2 blast, instead of sand blast.
wb, my first thought was to try to tint some Thompson's Waterseal. It sprays on easy, penetrates and doesn't require any wiping or topcoat. BTW, welcome to the forum.
Thanks, Troy. We'll get some and test it.
It doesn't say on their site whether it's a poly coating which stays on the surface (which I don't want), but seems to imply that it sinks in.
Oh--just read that they say to "remove puddles within 15 minutes by redistributing to dry areas or wiping off" which I was trying to avoid. But that's full strength--I could try the thinning truck I was going to try o the linseed oil on this.
I also wonder if it's less of a fire hazard?
Best,
Brad
have you considered spraying an oil/varnish blend? MS, BLO, & dull P&L 38 would probably give you what you want.
wb, I've never had a problem with Thompsons puddling on vertical surfaces. I usually spray it with a pump-up sprayer and just concentrate on just laying on a good heavy coat. Typically, it just soaks right in.
Dan S: Thanks for the alternative formulation--we'll try that too.
TRBaker: Great to hear you've actually done this--just the real-world feedback I was hoping for. There are some horizontal surfaces, but relatively few, so it's not an impossible effort to wipe them if necessary. Do you use it full strength, or thin it (if so with what) for easier spraying?
right out of the can, into a pump-up sprayer, and onto the wood.
Thats exactly what i do. Makes pretty quick work! I use that method with exposed brick walls in the city too. Its rad
Great, guys--thanks! I should be testing this in about three weeks and I'll follow up to let you know the results.
One full wall (the "short" one: 45') is all exposed brick: 11' at the eaves, up to maybe 20' at the ridge. Good to know it'll work on that, too.
(If anyone else has other formulations please post them even though these sound good, we might try a few.)
  • 26,012 Total Members
  • JAR Newest Member ·
