sbarton22 Posted November 17, 2013 Report Posted November 17, 2013 Ok, I'm getting ready to launch my biggest project to date. I'm building a built-in bookcase and window seat. I'm building it in a room that only has finished drywall. No floor covering. No base boards. No window trim. At this point, I'm in the conceptual design phase. I think I have the big idea.I and shooting for a very modern bookcase with fixed shelves with some of the bays enclosed with a door made of slats (versus a solid panel). The case cradles a "floating box" that is the window seat. The whole thing is slightly angled. So, the left side of the window seat is about 18" deep and the right side is about 24". The bookcase varies from 12" to about 18". The case is going to be walnut. The box will be painted MDF. And finally, the interior of the box will be some kind of lighter color plank, possibly a tongue and groove with a small chamfer to enhance the "plankness". I was also considering some salvaged wood, but I have yet to source that, so I don't want to commit to it. The kick space and the filler at the ceiling will probably painted black or stain walnut super dark to create a reveal and hide the imperfections of the existing space. I'm showing this rough model to get more eyes on it as a sanity check. Does anyone see any major constructability issues?. I'm not sure if I need a permit for this. I think I will have to relocate one, if not two outlets, so there may be a little drama there. The box will be framed by 2x4's I plan on bolting to the wall's 2xs. This may be a dumb question, but would I have to remove the drywall or can I bolt through it? I feel like surface area will be great enough that it shouldn't crush the drywall, but I'm not sure. Other than those couple of items, I think this is pretty straight forward stuff. Yes, I need to work out the details, but I think conceptually, this should work. Any thoughts would be appreciated! Quote
TRBaker Posted November 17, 2013 Report Posted November 17, 2013 Outstanding design!!! I really like the whole concept. The only thing that I would advise is running some half inch threaded rod from the bottom of your outside box corners to some joists above. If they don't line up with joists, then lay a 2x across several joists and secure them through that. This will give you good support where the weight will tend to effect the box the most, and will take any "bounce" out of it. 1 Quote
sbarton22 Posted November 17, 2013 Author Report Posted November 17, 2013 I like the suggestion. I'll ad it to the list. Quote
