Design Review for Entertainment Center / Desk
There isn't a design section, so maybe this is the place for this. I'm designing an entertainment center/desk and am looking for some input. It will support a 32" TV that doubles as a monitor for a MacMini. There is a 1 inch board directly below the top of the case that will pull out to support the keyboard and other desk paraphenalia. There isn't a ton of storage, but in the post-CD, post-DVD era we don't really have much to store aside from the Mac, and an external hard drive.
Design motifs - I've based the design off the Queensboro Bridge in NYC. We used to live in an apartment overlooking the bridge.
- I've simplified the geometic pattern of the bridges trusses on the drawer front.
- I've used pegs throughout inspired by the bridge's rivets
- The arches in the legs are similar to those in the base of the bridge
Questions:
1. I've used "pegged miters" for top case joints. I've never seen this used before. Think it's stable enought for a 32" TV?
2. The TV will be putting quite a bit of weight on the base, but do you think tipping will be a problem with a little weight on the keyboard tray?
Thanks
Paul
post-6563-0-56941900-1386476637_thumb.jp
post-6563-0-12899800-1386476646_thumb.jp
post-6563-0-35642600-1386476717_thumb.jp
What are the dimensions?
Looks sturdy enough to support the tv but, I would be concerned about it tipping forward too easily.
31" H x 32" L x 15" D. Maybe anchoring it to the wall is a best practice regardless of the desktop, considering we have a toddler.
Anchoring to the wall would definitely be good idea!
Looks pretty cool!
That miter that supports the bottom of the case looks pretty cool. I don't see a problem with the overall strength for the uses you suggested.
How are you going to support the shelf when it's at full extension?
I was thinking about undermount drawer slides.
-->  1. I've used "pegged miters" for top case joints. I've never seen this used before. Think it's stable enought for a 32" TV?
I've done this before on picture frames, not on a case joint.  I will say it can be tricky to glue up.  Once you start banging on the pegs you can knock the joint out of alignment.   A mitre joint that long is difficult enough to join precisely.
Splines are probably easier than pegs, in terms of glue up and assembly, but given the size of the case might be difficult to cut.
I'm considering getting the Woodpecker boxclamps and hoping those can hold the miter together during the gluing, drilling, and peg pounding.
