water based poly fail
Long story short.  I built custom sapele cabinets for a kitchen remodel.  All cabs were sprayed with sherwin williams polyacrylic 3 coats.  Then as added protection, all drawer and door fronts were finished with a hand applied coat of the same finish.  Yes, light 180 sanding between all coats.  Now the problem.  After 3 months, the homeowner brought me back to see that there are grease stains in several places from her cooking (bacon, chicken, etc).  the grease won't wash off, and is noticably darker and discolored.  Why would this happen, and how can I fix this?  Yes, they were brand new gallons of finish.  I don't want o apply an oil finish, because it probably would change the color of the cabinets, and then I'd have to redo everything.  I'd rather just apply a fix to the cabs new the stove.  Any suggestions or answers?  thanks in advance.
~seriousturtle
I think you would be better served contacting your Sherwin William person telling them what has happened. They should help you work around the issue. Wonder how long you let the cabinets dry down before install?
-Ace-
~seriousturtle
Sanding 180 between coats after 3 coats your going to be way to thin. Top that with hot oil on a WB poly. CV would have been a better finish. Call it a learning experience. Strip undercoat with vinyl and spray with CV 5mils dry. Cook top areas need extra care.
I'm new to waterbornes but have done some research. The waterborne industry is fast growing and it seems there are more marketing details than technical details on products. Like PB said, sanding with 180 is way too aggressive and 400 or 600 is all you should need between coats. Second, a polyacrylic product is usually a lot more acrylic and than poly from what I've read and not a good product for table tops and cabinets. For this you want a pure poly product and some manufacturers will market cross-linking for extra durability. I did some real-world durability tests about a month ago using different waterborne topcoats:
I know that CV is a better finish, but the fumes are so bad in my small shop when spraying, that WB is the way to go for me.  Is there a wipe on product you think might work after sanding with maybe a 220?  Can CV or even a pre-cat be wiped?  I just need something that's as clear as WB to match the existing.  Thanks for the replies so far.
There are plenty of good WB products. Bottom line is all of them need to be applied correctly. If your not putting down 4-5 mils dry your always going to have warranty complaints. You should not be sanding between coats.
The amount of retarder needed with the perfect speed rate to wipe on a spray finish is just inoperable.  You won't be too happy with the results.
Look into KEM Aqua 'lacquer' or CAB Acrylic lacquer.
  • 26,009 Total Members
  • Joseph b Newest Member ·
