Hello,
I am having trouble with my Delta Unisaw. When the blade is raised the motor pulley is coming in contact with the raising shaft. Nothing seems to be loose but I did find what looks like a drift pin in the bottom of the cabinet. Can't find where that came from. Any ideas?
Yes, the set screws on the pulley are loose, the key has fallen out and the pulley has walked out on the shaft. This happened to me last year. I took the opportunity to replace the belts with link belts. Unplug the machine, remove the blade, loosen the motor. At this point if you are not going to change belts, you should be able to push the pulley back on the shaft, insert the key and torque down on the set screws. I now check this yearly.
BRuce
Hey thanks, right on the money! I have to call some of my friends and locate a gear puller. The pulley spun on the the motor shaft about a quarter inch. Will post an update. Thanks again!
Got the pulley off, back on and properly aligned . Saw runs great. I will have to keep an eye on those set screws in the future. Thanks again for the info, it was a great help. Happy wood working to all!
I'm with you Bruce on the bearings. Just getting the pulleys in alignment has really improved the performance of the saw. Runs a lot smoother with less noise. Nice to have this resource to turn to. I tried to contact Delta and got a recording to call back on December 19??? Also contacted Northwest Power Tool, where I purchased the saw back in '05, they didn't even have a clue.
Mike
To be fair, I was only able to help because I had exactly the same problem and indications that something was wrong. I think these forums are the best place to turn since there are hundreds of different and seldom see problems that just one member may have encountered. Manufactures may not have seen this exact problem or the symptoms may have been different, like the pulley fell off. :-)
BRuce
To me, that's neat....come to the forum, state a problem, find someone with the exact same saw with the exact same problem who can say exactly how to fix it....2 people on opposite sides of the country. Boom... fixed....I love it.
I had a similar issue with my 12" Craftsman bandsaw. The pulley set screws would work loose and the pulley would slide out of position. The first time I just put everything back together and went on. It did it again so I put medium duty Loctite on the set screws.It's not hard to fix but you just about have stand the saw upside down to get at the pulley.
Yes, pretty cool that I was able to connect so quickly and get the problem fixed. Also, I did put some medium loctite on the set screws as well. I will definitely be checking the pulley in the future for any sign of movement.
